April 29, 20188 yr comment_147916 I need to replicate one part several times. It's 5.5" X 2" X 3/4". Material just needs to be fairly rigid, as in mdf or mdo. If you're interested, shoot me a PM. Thanks in advance for any replies. Report
April 29, 20188 yr comment_147931 You didn't describe anything?? except size and I have heard size does matter. Report
April 29, 20188 yr Author comment_147943 Particulars can be supplied, along with pictures. PM me if you're interested. Report
April 30, 20188 yr comment_147959 2 hours ago, Gene Howe said: Particulars can be supplied, along with pictures. PM me if you're interested. I'm Interested, but don't have a cnc, any Top Secret stuff peaks my interest. Herb Report
April 30, 20188 yr comment_147960 3 minutes ago, Dadio said: any Top Secret stuff peaks my interest. HF is in the mix Mr. Herber... Report
April 30, 20188 yr Author comment_147962 23 minutes ago, Dadio said: I'm Interested, but don't have a cnc, any Top Secret stuff peaks my interest. Herb Nothing secret about it, Herb. Take look at the pictures I posted about the lock miter jig. The orange plastic piece that the red bit is poking through is what I need. It's proprietary but, Jointec went out of business many years ago. Can't get replacements. Report
April 30, 20188 yr comment_147980 1 hour ago, Gene Howe said: Nothing secret about it, Herb. Take look at the pictures I posted about the lock miter jig. The orange plastic piece that the red bit is poking through is what I need. It's proprietary but, Jointec went out of business many years ago. Can't get replacements. Oh Just make your own, Gene, I do it all the time. What you do is cut a piece the dim. to fill the space between the sliding fence boards,and insert it and tighten the boards against it. set the cutter to height, set one end of the fence at the mid point of the cutter leave the other end loose, turn on the cutter and slowly rotate the loose end thru the cutter cutting out the profile of the cutter. This would also serve as a guide to set up the cutter next time around. I make zero clearance inserts for different bits that way. Herb Edited April 30, 20188 yr by Dadio Report
April 30, 20188 yr Author comment_147982 Thanks, Herb. I'll give that a spin....so to speak.🤔....Whoa there, Nellie. Wha hoppin to to our smilies? Report
April 30, 20188 yr comment_147989 6 hours ago, Gene Howe said: Thanks, Herb. I'll give that a spin....so to speak.😬....Whoa there, Nellie. Wha hoppin to to our smilies? I think it is sick call the doctor, maybe just anemic. OOP's they all caught it.🙄 🦀🐍 Herb Report
July 13, 20188 yr Author comment_153999 3 hours ago, John Moody said: @Gene Howe did you ever get the piece you wanted made? Made my own. Picky work but three is enough for now. Report
