September 19, 20179 yr comment_125084 I decided to make a Christmas ornament using wood and acrylic. I wanted to be sure the glue joins held, so I used Wood Fuse. Not sure what else I could count on that would hold good and not show. I carefully lined up the joint on one side and squeezed with my hand. I turned it over as I got a clamp and saw that it was slightly misaligned on the opposite side. It was glued so tight that I couldn't move it at all. Wow. I clamped it as it was. I think I can make up (cover up) for the alignment. I've used that glue with wood and there is always a grace period of a few minutes. NOT SO WITH WOOD AND ACRYLIC. Report
September 19, 20179 yr comment_125089 I used it to mount a small piece on a waste block. I wondered if it could take the lateral pressure from turning. Held perfectly. I'll be using it for more things like this. The only clamp I used was the tail stock pressure against the piece while it dried. Report
September 19, 20179 yr Author comment_125094 I have found myself using it much more than I thought I would. Not just wood. I have NEVER had much luck with instant glues, except to glue things together you don't want.........like fingers This stuff holds where most instant glues won't. I got it free, thru PWW and DAP. I didn't think I"d use it much. After I tested it, I like it a lot. HOWEVER, you must remember it is CA glue and handle appropriately. Report
September 19, 20179 yr comment_125104 1 hour ago, Ron Altier said: CA glue and handle appropriately. Remember to let it dry before turning on the lathe! I have spots on my glasses due to my forgetfulness! Report
September 19, 20179 yr comment_125122 How is this different than other CA glues? Have never used it but it sounds as though it might be handy to have around. I use quite a lot CA glue but our club buys it from Starbond once or twice a year. Steve Report
September 19, 20179 yr Author comment_125141 The main difference is that it is set up in 30 minutes to full strength. I know little about the other CA glues and have not had much success with them. This stuff does work. It has also worked on some things where I couldn't get the super glue to work. Report
September 19, 20179 yr comment_125163 44 minutes ago, Ron Altier said: The main difference is that it is set up in 30 minutes to full strength. I know little about the other CA glues and have not had much success with them. This stuff does work. It has also worked on some things where I couldn't get the super glue to work. Is it watery like CA glue or more like a gel. Report
September 19, 20179 yr comment_125187 Dan, this is more the consistency of a gel. I have used my sample bottle for a couple now. I am happy that I was able to use it a couple weeks apart. Usually the super glues are a one shot deal for me. Cal Report
September 19, 20179 yr comment_125217 3 hours ago, clhyer said: Dan, this is more the consistency of a gel. I have used my sample bottle for a couple now. I am happy that I was able to use it a couple weeks apart. Usually the super glues are a one shot deal for me. Cal Cal, it is said you should never touch the tip to the piece being glued. Might pick up some moisture and the glue will harden in the tip. Same deal when wiping the tip. Make sure the wiper is very dry. Report
September 19, 20179 yr comment_125245 This brings up a question for me. Remember, I am still in the baby steps learning how to turn. When using a glue block to mount your turning, as opposed to a mortise, tenon, screw block, etc., how do you separate the turning from the block when you are done turning? Do you use a parting tool, cut it off at the band saw, or what? I too have shied away from using CA for just about anything because all it seemed to do was "size" the wood surface. This might be a good alternative for smaller projects once I learn how to "unglue" properly. Report
September 19, 20179 yr comment_125247 8 minutes ago, PostalTom said: This brings up a question for me. Remember, I am still in the baby steps learning how to turn. When using a glue block to mount your turning, as opposed to a mortise, tenon, screw block, etc., how do you separate the turning from the block when you are done turning? Do you use a parting tool, cut it off at the band saw, or what? I too have shied away from using CA for just about anything because all it seemed to do was "size" the wood surface. This might be a good alternative for smaller projects once I learn how to "unglue" properly. I parted off my last turning, attached using CA, with a narrow shop made parting tool. I haven't tried the DAP CA on anything very large. For larger stuff, I often use a waste block and a paper joint done with TiteBond II. I use a brown paper bag for the paper. Report
September 20, 20179 yr Author comment_125256 The wood pieces I glued with wood glue, came apart as I turned the piece down. I reglued with Dap wood fuse. Dried an hour and it also came apart. Maybe it wouldn't if I had cleaned the pieces. Will try that tomorrow and reglue with Dap It is Yellow hart and maybe this piece is oily. Edited September 20, 20179 yr by Ron Altier add Report
September 20, 20179 yr comment_125258 Like Lew if I use glue block I like the paper joint. Then you would use a chisel in the joint and when forcing it apart the paper will split. This does leave a cleanup on the bottom. Method 2 is CA . The glue block should be slightly concave _( )_ . When you remove the turning a sharp rap on the joint will rupture the CA since it has no lateral strength. A very good video on this method by Lyle Jameson on You Tube. VIDEO A third method is to use hot melt glue. Use the sane prep method Lyle shows. An easy to remove is with a heat gun. Hope some of this helps. I rarely use a glue block since I prefer scroll chucks. Report
September 20, 20179 yr comment_125279 9 hours ago, Gerald said: Like Lew if I use glue block I like the paper joint. Then you would use a chisel in the joint and when forcing it apart the paper will split. This does leave a cleanup on the bottom. Method 2 is CA . The glue block should be slightly concave _( )_ . When you remove the turning a sharp rap on the joint will rupture the CA since it has no lateral strength. A very good video on this method by Lyle Jameson on You Tube. VIDEO A third method is to use hot melt glue. Use the sane prep method Lyle shows. An easy to remove is with a heat gun. Hope some of this helps. I rarely use a glue block since I prefer scroll chucks. The lyle Jamieson videos are very good IMO. He really likes CA, I prefer hot glue which I learned from Carl Jacobson's early videos. Either works well with the right preparation. Report
October 4, 20179 yr comment_127004 https://www.amazon.com/DAP-00157-Rapid-Curing-Adhesive/dp/B01DA6X1OC/ref=sr_1_1?ie=UTF8&qid=1507139758&sr=8-1&keywords=Wood+Fuse Is this the product you are talking about? Thanks Jim Report
