July 19, 20179 yr comment_117114 43 minutes ago, kmealy said: Gee, you guys must be cheap frugal. No one's mentioned this, just $685. Might need two, though. Call me frugal, cheap or just a plain 'ole woodhack, but if I spend $685 I'll probably waste it on, Oh, IDK, a 14" band-saw, a new table-saw (pre-CPSC interference), maybe a lathe with a full complement of tools or ???? I'm pretty sure FT won't miss my business nor me their "special priced" tools. Report
July 19, 20179 yr comment_117125 17 hours ago, Pat Meeuwissen said: Guys, a couple of suggestions that have some merit but the fact that the driveway slopes is a big problem. The table I'll be gluing up is 4' x 7' so I need a good size top. Found this while searching today. https://s-media-cache-ak0.pinimg.com/originals/51/be/cf/51becfe68345dfafd7eede656d4bc143.jpg Could add a set of adjustable levelers to one side of the supports to get it flat and level. Throw some ply on top for the final assembly?? Dan, your suggestion while very handy would not get past the budgeting committee (aka my wife lol) You could put leveling legs or all thread on one side to adjust to flat and level. Using all thread , drill hole in 2x2 and put tee nut in hole to allow adjustment. Report
July 19, 20179 yr Author comment_117127 10 hours ago, MT Stringer said: Pat, the work table doesn't have to be level, just flat. Very true just that its so angled that things tend to slide or roll off. Report
July 19, 20179 yr Author comment_117128 23 hours ago, Ron Altier said: Years ago I picked up a heavy duty Work Mate at a garage sale for $25. It is really sturdy and folds for storage. . I then built a table top that clamps in the table vise. It can easily be removed to use the table vise or to put another size top on. Mine has become my permanent small projects table and I have it modified somewhat like a jewelers bench. It is still removable, if I want I have one of these and use it with a dolly to move my shoebox planer around. Report
July 19, 20179 yr comment_117157 3 hours ago, Pat Meeuwissen said: Very true just that its so angled that things tend to slide or roll off. I feel your pain. My drive is the same way. Report
July 19, 20179 yr comment_117175 Search on "adjustable height sawhorse." Lots of plans. Uphill low, downhill high. Report
July 19, 20179 yr comment_117185 At one time, Menards carried 1 1/8 thick particle board plastic laminated on both sides, one side was white, and one side maple colored. I think it was 4 x 8, but not too sure about that. That, on a couple sawhorses, would be pretty substantial. Report
July 20, 20179 yr Author comment_117243 13 hours ago, kmealy said: Search on "adjustable height sawhorse." Lots of plans. Uphill low, downhill high. Here is one I found that always for adjusting all the legs individually, as well as the height. Your search term helped me find it, thank you. Because the driveway is so "wonky" I think these will work better. Report
July 20, 20179 yr Author comment_117244 13 hours ago, PostalTom said: At one time, Menards carried 1 1/8 thick particle board plastic laminated on both sides, one side was white, and one side maple colored. I think it was 4 x 8, but not too sure about that. That, on a couple sawhorses, would be pretty substantial. Tom, I'm not sure this would fit into the "light" category. LOL Report
July 20, 20179 yr comment_117370 11 hours ago, Pat Meeuwissen said: Tom, I'm not sure this would fit into the "light" category You're right Pat. I should have re-read the original post. I was just focusing on the 4' x 7' size. Who carries that adjustable saw horse? That is pretty cool. Report
July 20, 20179 yr Author comment_117374 46 minutes ago, PostalTom said: You're right Pat. I should have re-read the original post. I was just focusing on the 4' x 7' size. Who carries that adjustable saw horse? That is pretty cool. http://www.instructables.com/id/Portable-and-Adjustable-Sawhorses-1/ Report
July 21, 20179 yr comment_117387 1 hour ago, Pat Meeuwissen said: http://www.instructables.com/id/Portable-and-Adjustable-Sawhorses-1/ 2 hours ago, PostalTom said: You're right Pat. I should have re-read the original post. I was just focusing on the 4' x 7' size. Who carries that adjustable saw horse? That is pretty cool. Maybe you've both already looked at these IDK...if not another idea for you to ponder. Each leg is individually adjustable... Stanley Adjustable Sawhorse---Lowes Report
