March 23, 20179 yr Popular Post comment_103478 I wanted to sit as I turned on my mini. I had to remove a lot of stuff and make some major changes. The lathe center is about my elbow level and . the base is 25inches from the floor. I am still moving my tools and rearranging. If the stool is too high, I see that HF has an adjustable one. My stool is 24" and the HF one is from 15 to 20" Haven't had time to turn, clean up and honey dos Report
March 23, 20179 yr comment_103493 26 minutes ago, HandyDan said: Looks good. Let us know how you like it. I'm curious too. It seems as though it would really limit range of motion. Do you plan to tilt it ever? Steve Report
March 23, 20179 yr Author comment_103498 After I've turned a couple projects, I'll reevaluate and see. I added the (Rube) vacuum dust collector and I've moved some tools. I've spent most of today cleaning up my mess and honey dos. A MAN GOTTA DO.........WHAT A MAN GOTTA DO,,,,,,,,,,,,,,,,,,,or what she tells him Report
March 25, 20179 yr Author comment_103801 I like it a lot, however I may make one adjustment. Replace the stool with a bench type stool so I can slide over while working. This one is must be moved each time I want to work the other side Report
