January 26, 20179 yr comment_94636 Accidentally caught a pc. of wood and the blade jerked it sideways leaving a bend in it. Any way to straighten it out. I paid a good bit for it, so when you are cheap, cheap, you try to salvage it! Thanks! Edited December 8, 20178 yr by Ron Dudelston tags added Report
January 26, 20179 yr comment_94639 time for a new blade. BS blades are pretty brittle, so trying to bend it back will only increase the chance of it snapping. live and learn. keep a few spares handy. Report
January 26, 20179 yr comment_94641 Happened to me once. Success depends on how much your blade is bent. I put my blade across an anvil and gently tapped it flat. Go slow. If it snaps later, so what? hat Report
January 26, 20179 yr comment_94662 I am thinking, depending on the kink, that you could be asking for a catastrophic failure next time the blade was put into "heavy" use or maybe after the "x" time you "gently" used it. Report
January 26, 20179 yr Author comment_94667 It still cuts, but it makes a wider cut and it is not very smooth. I am thinking that if I take a sharpening rock against the sides, it might help some. Report
January 27, 20179 yr comment_94669 15 minutes ago, oldwoodie said: It still cuts, but it makes a wider cut and it is not very smooth. I am thinking that if I take a sharpening rock against the sides, it might help some. That's been my experience. It can ruin a project Report
January 27, 20179 yr comment_94673 Anvil and nylon head hammer/mallet...gently gently does it and no guarantee... Report
January 27, 20179 yr comment_94683 It's always worth a try, but test it on scraps so that it doesn't end up costing you more than the cost of a new blade. Report
January 27, 20179 yr comment_94689 6 hours ago, hatuffej said: Happened to me once. Success depends on how much your blade is bent. I put my blade across an anvil and gently tapped it flat. Go slow. If it snaps later, so what? hat Have you ever had a broken blade come out of the saw on you? This happened to my wife this summer. She was fortunate that the blade slapped the back of arm after it bounced off the table and stock but did not cut her. My recommendation is do not use it. If or when it breaks it could come out of the saw like mentioned above. It is nice to be frugal but we need to be sure that frugality does not come at a greater cost later. Report
January 27, 20179 yr comment_94690 cut out the kink and braze/weld the band back together.... https://www.youtube.com/results?search_query=welding+bandsaw+blades Report
January 27, 20179 yr comment_94722 10 hours ago, John Hechel said: Have you ever had a broken blade come out of the saw on you? This happened to my wife this summer. She was fortunate that the blade slapped the back of arm after it bounced off the table and stock but did not cut her. My recommendation is do not use it. If or when it breaks it could come out of the saw like mentioned above. It is nice to be frugal but we need to be sure that frugality does not come at a greater cost later. Yes, one time a blade snapped and it stopped instantly because it was no longer held and driven by the drive wheel. There is virtually no momentum to keep it going and the blade is almost entirely enclosed. My answer to his question was a suggestion to consider repairing it. Its a personal choice and I would do it again. I also have considered Stick's suggestion to remove the bend and re-weld it. There is an element of risk associated with that also. Report
January 27, 20179 yr comment_94726 Do like someone did???? Cut it up for scroll saw blades . You might set a record for the largest piece of wood cut by a scroll saw maybe a 6x12 or bigger. That would put you in the hall of shame. Report
January 27, 20179 yr comment_94739 http://www.rockler.com/olsonreg-all-protrade-band-saw-blades-93-1-2-fits-most-14-delta-jet-etc a new blade runs about $20. buy a new one and move on. blades wear out, budget for it and accept it. Report
January 27, 20179 yr Popular Post comment_94742 I break them up into 6" pieces, put them together, alternating the teeth and, tape each end of the bundle. They make decent rasps. The 1/4" and 3/8" work best. No 1/2" or 5/8" blades have ever broke for me. Don't think they'd make good rasps, anyway. Report
January 27, 20179 yr comment_94743 4 minutes ago, Gene Howe said: They make decent rasps. excellent... Report
January 28, 20179 yr comment_94849 On 1/26/2017 at 6:49 PM, oldwoodie said: It still cuts, but it makes a wider cut and it is not very smooth. I am thinking that if I take a sharpening rock against the sides, it might help some. Toss it and learn. By grinding off the metal you make the blade THINNER and more likely to break. Plus the tooth set is already off. Count your fingers and your lucky stars it didn't catch YOU!!! By the way, you might have had your blade tension loose and that's what caused it to kink. I've snapped blades through no fault of my own and it's a very scary experience. Replace on the side of caution. Your wife will thank you for not having to wipe your butt while your fingers are healing cause you tried to "save a few bucks". Report
January 28, 20179 yr comment_94920 I had a blade break a couple of years ago and the topside of the break came don to the table and got me right in the center of my index fingernail. Pure bad luck? Probably. Would I have spent as much as 35.00 on a new blade to avoid the discomfort of the injury and the healing process! HELL YEAH! The pain of the expense is forgotten long before the pain of the injury would be. And depending on when, how and just where it breaks in its rotation on the saw things could potentially go worse for you than they did for me. Report
January 28, 20179 yr comment_94976 I have had one break and I have no idea why. My hands were far from the blade at the time but it was absolutely a scary moment Report
January 28, 20179 yr comment_94982 if you are keeping score, it seems the 'get a new blade' faction is carrying the day. get a new blade. way, way cheaper than an ER visit. Report
