January 22, 20179 yr Popular Post comment_93980 Moving on to bigger things in inside out turning. This vase is 9" tall overall. The inside out turning is old growth Fir and the base is Purple Heart. The insert is removable and can be removed for cleaning and makes it possible to use fresh flowers with water if desired. Report
January 22, 20179 yr comment_93981 That is nice! The burned lines on the inside really add to the "how did he do that" factor!! Report
January 22, 20179 yr comment_93985 Neat idea Dan, every time I think of an inside out turning I think of ornaments. Nice vase and the burn lines inside are a clever detail. Steve Report
January 23, 20179 yr comment_94085 14 hours ago, Stick486 said: you out did yourself... Guess you could say "he out did himself working inside" this weekend or perhaps "instead of staying in he went out"... Regardless, great job Dan...clever idea for a project and well executed. Thanks for taking time to take pictures and share. Report
January 23, 20179 yr comment_94088 4 minutes ago, Grandpadave52 said: Guess you could say "he out did himself working inside" this weekend or perhaps "instead of staying in he went out"... yeah... Report
January 23, 20179 yr comment_94092 6 minutes ago, Stick486 said: yeah... ...or..."instead of turning in, he turned out" Report
January 23, 20179 yr Author comment_94103 Mom always said there were times she worried but I turned out OK. Report
January 23, 20179 yr comment_94105 4 minutes ago, HandyDan said: but I turned out OK. and you got this from where???? Report
January 23, 20179 yr Author comment_94132 2 hours ago, Stick486 said: and you got this from where???? Mom said the whole sentence. Report
January 24, 20179 yr Author comment_94260 2 hours ago, Smallpatch said: NOW YOU HAVE DONE IT. Your starting to PISS me off. What's the problem Jess? Report
January 24, 20179 yr Popular Post comment_94267 I can't do that crud using the lathe so now I'll have to start and try new stuff to try and stay up with you. Can't you just be a wall flower and sit in the corner, that I can do.... I printed a bowl I saw on Pinterest a month or two ago. If I can find it it will keep you busy while I try and do some catch up. Oh, the color looks good also.!!!!!! Report
January 24, 20179 yr Author comment_94274 58 minutes ago, Smallpatch said: I can't do that crud using the lathe so now I'll have to start and try new stuff to try and stay up with you. Can't you just be a wall flower and sit in the corner, that I can do.... I printed a bowl I saw on Pinterest a month or two ago. If I can find it it will keep you busy while I try and do some catch up. Oh, the color looks good also.!!!!!! Thanks Jess but that's how I feel when you put up one of your tea pots. We all have a niche. Edited January 24, 20179 yr by HandyDan Report
January 24, 20179 yr comment_94277 21 minutes ago, HandyDan said: We all have a niche. Really? I've been searching for mine for 60 years. Report
January 24, 20179 yr Author comment_94278 Just now, Gene Howe said: Really? I've been searching for mine for 60 years. Your niche is a strong will. You haven't given up! Report
