A cabinate from yesteryear...
simple credenza out of Ambrosia...
Wow and wow!
I love the Ambrosia!
thanks....
me too.. to the point I make my own...
Wowser!
Sweet and more!  Beautiful.
Love it! Gotta ask, what is Ambrosia (besides the food of the Gods)?
John
John
Ambrosia Maple is technically not a specific species of Maple, but rather a general description of any type of Maple that has been infested by ambrosia beetles. The beetles bore into the tree, and with it bring fungus that discolors the wood.
If you take wormy woods and spalt them you can have the same or near same results...
Spalted Maple is technically not a specific species of Maple, but rather a general description of any type of Maple that has been allowed to begin initial stages of decay, and then subsequently dried preventing further decay...
Edited by Stick486
I really like the grain and the execution of the cabinet. The doors and drawers are all perfectly matched to the opening.
I do have a design suggestion for the next project -- when I look at the cabinet, the knobs and hinges really stand out ... I would have used hidden hinges and darker handles. Please don't take this as criticism, because I really like the cabinet -- just a comment on the choices that I would be made.
In the early 2000s, tree-heavy Colorado suffered an outbreak of mountain pine beetles, decimating some 70% of the lodgepole pine population. In recent years the infestation spread south as far as Mexico, and north through Wyoming, Montana and Idaho to reach western Canada, where the current outbreak dwarfs the Colorado infestation. Colorado's loss of tree acreage is in the low millions; it's estimated British Columbia will lose some 44 million acres of pine trees.
The mountain pine beetle typically lays its eggs under the bark of dead pine trees, and historically the bugs' population was kept in check by the winter cold. But as North America has recently had warmer-than-normal winters, the MP beetle's population has exploded. With not enough dead trees to go around, the beetles start laying their eggs into live trees.
When that happens, the live tree becomes infected with a blue fungus that arrests its internal flow of nutrients. Its pine needles turn red, its bark starts to turn grey, the internal wood takes on a bluish tinge, and the tree dies. Here you can see dead trees from literally miles away...
this is what you get....
Edited by Stick486
I'm w/ you but what you see in hardware was the customer's choice...
this an older map but you get the idea how large the blight is.....
thanks Lew...
Stick, that is one solid looking piece of art, I love it!
Image result for Fantastic job
Thanks for the lesson, @Stick486! Learned a few more things I didn't know. So Ambrosia is basically similar to Spalted. I believe other hardwoods can have the spalting as well?
John
yes... quite a few...
John
Spalt Your Own
A Recipe for Creating Spalted Wood
     Since the question of spalting comes up time and again, I will share a description of what I use when the natural ingredients aren't available.
     A "brew" of some kind is required when the conditions for natural spalting do not exist. There are a lot of ways to induce spalting. Like everything else in woodturning, nothing is "tried and true". You will have to experiment. Some wood spalts. Some wood just rots. Others (cherry and walnut) don't do much of anything.
     This spalting brew has everything necessary for almost anything to grow in any wood that wants to spalt. Use it on maple, birch, beech, sweetgum, oak, alder, holly, pecan and just any hard wood you wish.
  • 1-qt water
  • 2-scoops Miracle grow
  • 2-cans beer, drink one and put th other in the spalting brew.
  • 1-qt horse manure, doesn't have to be fresh, but the ammonia odor should still be present when it gets wet.
  • 1-qt dried oak leaves
     There is nothing sacred about any of the ingredients as long as we have the nitrogen, organics, ammonia, sugar, malt extracts, tannins, and leaf molds - everything necessary for all kinds of things to grow in the wood. The only additional ingredient is heat.
     You can use packaged steer manure from the garden store and add a half cup of household ammonia. Don't use the sudsing type because it contains detergents which will kill the growth.
     All leaves contain some amount of tannins, oak leaves contain more than others. Wood chips will not work because you need the leaf mold. You can use chunks of rotten wood to replace the leaves, but the spalting is different with more of an area discoloration than the lines we are looking for. The large black areas look good in oak, but not other wood.
     Put the wood in a trash compactor bag (they are heavier than the others) when it is fresh cut and still wet. If the ends have dried, saw off a slice to open up the wet wood. It works better in wood cut in the spring when the sap is up and the free-water in the wood is at its highest. Apply a liberal amount of the brew on each end, and seal the bag.
     Now we will need that last ingredient, warmth. Store the sealed wood indoors under an old electric blanket during the winter months when the outdoor daytime temperature is below 65-degrees. Otherwise, outside is fine.
     Check it after 2 months. You will be looking for a black slimy mess on the wood, with things growing out of it. Mushrooms are good. Clean it up and split it in half if you can. If it isn't what you want, put the halves together and back in the sealed bag.
     You can use chunks or shavings of spalted wood instead of the brew, but it takes forever, and sometimes doesn't start because it is dead. The brew is faster, more reliable, and gives better spalting.
     You could just seal the wet wood in the bag without adding anything, but some will spalt, and some won't.
     And, when all of the ingredients are available in nature, then you don’t need a brew to start the process. Just throw the wood under a tree, let the grass grow up around it, and nature will take its course. Covering it with some leaves will help. Put something under it to get it off the ground, otherwise it will rot on that side.
Spalted wood isn't exactly rotten, but it's on its way. Spalting occurs in an early stage of the decay process, when various colonies of fungi stake their claims to a piece of fallen wood.  The characteristic blue-black lines that run through spalted wood actually represent the lines of demarcation between incompatible colonies of micro-organisms. But the specific biological facts aren't what interest most woodworkers in spalted wood, it's the fact that nothing else looks quite like it.
One way to get your hands on spalted wood - obviously - is to go on a field trip and gather your own naturally occurring specimens. You can also give Mother Nature a hand and "spalt your own". Either way, it helps to have a little background information.  Fortunately, there's no shortage of information on spalted wood, how to work with it, and how to make it. Here are a few resources:
If you access to Fine Woodworking's article archives (Taunton Press charges a nominal monthly fee for access to hundreds of articles) a good place to start is with sculptor Mark Lindquist's "Spalted Wood", which appeared way back in issue #7.  It's still one of the best overviews of the natural spalting process, how it plays out in various species, where to look for spalted wood, and how to prepare it for use.
"Spalting, a Fungus Amongus" by Andrew Hilton covers everything from how spalting works to working with spalted wood to making your own - and it's free.
If you don't happen to have a hardwood forest handy, you'll be glad to hear that creating your own spalted wood isn't a difficult process. Read "Intentional Spalting" from the Woodweb Knowledge Base for great discussion of various methods for encouraging and controlling the spalting process. "Producing Spalted Wood", published by the Forest Service's Forest Products Laboratory, offers a good overview and includes more technical information on the types of fungus involved in the process.
Again, thanks for the education.
John
we did our kitchen in wormy maple (ambrosia maple) a few years ago.
