December 28, 20169 yr comment_89775 Have a belt/disc combo center that has a broken drive belt. 14" long, toothed belt, to be exact. Model No. 113.226423. Did a short Google-Fu Search.......anywhere from $1 per inch to $44 for ONE belt. Yikes! I only spent MAYBE $15 on the machine at a garage sale. A belt that costs more than the machine? heck, Sears Parts wanted $24 for one...IF they have one in stock. Lately i don't trust Sears any further than I can throw the store. Looking for other options right now..... Old belt blew apart at the seam. I might go and check out sweeper belts today and see what they have. Let you know what I find out. The machine comes in handy on curved items..... Report
December 28, 20169 yr comment_89779 Maybe time for another rust hunt? Hope a sweeper belt can be found that matches the toothed wheel. I'm not holding my breath, though. Report
December 28, 20169 yr comment_89781 https://www.amazon.com/XL-140-14-inch-Rubber-Synchronous-Timing/dp/B00R1J90PY maybe Report
December 28, 20169 yr comment_89783 May help for a sub- http://www.pfeiferindustries.com/timing-belt-identification-replacement-i-30-l-en.html Report
December 28, 20169 yr Author comment_89786 First link sounds about the best match, Thanks. May have to have Craig order one for me.... Report
December 28, 20169 yr Author comment_89793 That will be my next stop in a little bit. belts on-line were going to take too long, and some were from China....will try to shop local, first. Like...right after Lunch. Report
December 28, 20169 yr comment_89810 Here's another place- http://www.jasonindustrial.com/power-transmission-belts.html Report
December 28, 20169 yr Author comment_89818 Ok, inorder to get this dang thing up and running until a regular belt can be ordered, I used a Vacumn Cleaner belt.....Eureka*U. Came in a 2-pack for $5. Hardest part was getting the belt stretched to go over the disc platten. ( Set screw to remove the platten it stripped out) Once I got the smooth rubber belt started onto the drive wheels, belt went right on, and still tight enough to drive the sander. Need to order a new guard piece for around the disc. Not a biggie,. Test run.......belts stayed put. new rubber oneand the 4x36 sanding belt. It also runs a LOT quieter than before. At least I now have a spare it case the first breaks. Thanks for the info on the new belts. BTW: Belts came from Lowes. Autozone could not find any in their stock. Report
December 29, 20169 yr comment_89850 @steven newman A few more options...: https://www.amazon.com/Replaces-113226424-Sander-Replacement-814002-1/dp/B00NCAZKPA http://www.fremontindustrialsupply.com/craftsman-814002-1-drive-belt-free-shipping/ http://www.ebay.com/itm/Sears-113226424-Sander-Replacement-Belt-814002-1-/121052805174 http://www.protooldirect.com/product/5019773/ Report
