November 10, 201610 yr comment_83532 5 hours ago, Dadio said: LOL you would, HAHAHAHA so would you like ''AWESOME'' better??? Report
November 10, 201610 yr comment_83573 and a quick blast of starting fluid (ether) in there won't hurt the wood and will, erm... disable the hornets... Report
November 10, 201610 yr comment_83612 11 hours ago, p_toad said: and a quick blast of starting fluid (ether) in there won't hurt the wood and will, erm... disable the hornets... Starting fluid? Really? I'll have to remember that. We have a BIG problem with yellowjackets here, but most nests (in the ground) are taken care of by the resident skunks. About three years ago, however, the little prickers set up home in the wall of the attached garage, then moved into the space under a step to the man-door. I kept hearing a faint buzzing, but couldn't figure out where it was coming from. By the time I DID figure it out, there had to be 5 or 6 thousand of the buggers in there. They chewed through 3/4" cedar siding, a layer of Ten-test, two 2x6s, and the drywall. It took me a week to get rid of them all, and I got one sting that made my hand look like a baseball! John Report
November 10, 201610 yr comment_83619 I just use bee bop or one of the other types of wasp/hornet killers. Sometimes, you can't get close enough to the nest with the starting fluid unless you turn the spray into a flame thrower - then that does not work well around a building. Report
November 10, 201610 yr comment_83628 3 hours ago, HARO50 said: Starting fluid? Really? I'll have to remember that. just use enough to get the job done and make sure there is no such thing as a spark or flame in the neighborhood or things will get very interesting right quick.. Report
November 10, 201610 yr Author comment_83631 3 hours ago, HARO50 said: They chewed through 3/4" cedar siding, a layer of Ten-test, two 2x6s, and the drywall. It took me a week to get rid of them all, and I got one sting that made my hand look like a baseball! John I had a similar situation in the living room. They got in through a bird block and some how got through the double top plate down into the wall cavity between the studs, this old house didn't have insulation,and they filled the space with their nest form bottom to top 8' hi. they had chewed out the drywall so just the paint was left, My wife found them when she was moving furniture and bumped the wall and her hand went through. Then they were in the house . took 3 different sprayings to kill them all and then had to tear it out and patch it after it was cleaned out. Herb Report
November 10, 201610 yr comment_83642 I have some nonflammable brake cleaner drops them in mid air. Report
November 11, 201610 yr comment_83675 I went through two cans of wasp & hornet spray, and there were still more every time I looked! Finally took the Shop-Vac and just kept it running until the entire nest was gone. Plugged the hose after spraying in the last of the bug spray, and left them there for a couple of weeks. John Report
November 11, 201610 yr comment_83766 On 11/8/2016 at 2:59 PM, Dadio said: I don't consider myself an artist or a craftsman, just having lots of fun, expressing my ideas. Herb Well I had trouble with that also when people started referring to me as an artist. Now I just go with it. Beats many things they could call me I guess. Report
November 15, 20197 yr comment_208900 I just use an old Squirt oil can with strait gas... Works great. If you get them in your house then sulfur candles work good. Report
