October 31, 201610 yr Author comment_81902 Why not use the laminate all the way up the steps and for the floor at the top? Everything would be nice and even. Good question Dan. When I purchased the flooring a couple weeks back I nearly did purchase the laminate treads. But when I asked them about the three open ended treads they said those would not be laminate, but plywood instead. When I asked about the bottom tread which has a return they said it would have to be custom made, also plywood. When I asked about the top step, that was also going to be unfinished wood. So I could see different looking treads and such not matching. Then I seen the retro pieces at Lowes. At least using these, they would all stain the same. Cal BTW - I got a reply from LL regarding the piece I posted above: My question - could I use that piece with laminate flooring? Answer: “Potentially yes however most laminates will have matching stair-nose.” Tech & Install from Lumber Liquidators Report
November 1, 201610 yr comment_82023 You could order an extra tread nosing to match and cut a 45 deg. on one end and cut a short return for the open ended steps. Herb Report
