November 26, 201511 yr comment_63532 Finally got to go to the shop, again. Planes have been rehabbed and shipped out, van is now fixed up. I can rip a few boards of walnut 5/4 stuff. needed three pieces. One will be the second long apron, the other two will be long stretchers under the bottom shelf. Ran into a problem, though. The foot part of the legs is too small... Which meant I had to cut the leg back about a 1/4" or some, just to get a flat area for the stretcher to land on. Which mad a change in tenon length, too. Needed to find out how long a tenon I could get by with.. Clamped a leg into the vise. planed the flat after the bandsaw had cut the waste off. Since two legs have the mortise for the apron chopped, I got the apron out and the other leg. A pipe clamp to almost hold things together. Yeah. Then i used a c clamp to hold a strecher close to where it will go, about evenly spaced between the two. Gave me a tenon length like this... pencil to mark a spot. Used a square to "carry" the line around. Marked both stretchers. laid out the toy list items...Backsaw, chisel, square, mallet. and started cutting tenons wasn't too hard, backsaw to the line, go 1/3 the way through, by eye. Chisel and a whack of the mallet to pop the waste off. chisel to pare flat, rotate and repeat. There was one that wanted to be a problem...as I was doing the long apron board.. yep, big old nasty KNOT. Well, I sawed down the usual 1/3 of the way. Chisel did NOT want to pop the waste off...hmm...Old School Way! I stood the board on it's end in the vise, and sawed off the waste. pared it a bit and laid the board back down. And finished it up. While doing the LAST tenon of the night's work (of course) I tried out a wooden plane as a shoulder plane. It has been a bit tricky to set, but I FINALLY got it to work... Figures. Well, stacked all all the parts back onto the bench, as it will be a few before I get down there again. Got a few short ones to tenon, and a bunch of mortises to chop. maybe by Sunday I can grab a bottle of Elmer's? Oh, BTW, I also got the bottom shelf out of the clamps, and planed smooth. Stay tuned.... Report
November 26, 201511 yr comment_63535 Whew! I got tired just reading about all that work! Nice Job! Report
November 26, 201511 yr comment_63536 Steve, Looks like we both get our wood from the same place. It requires a bit more work, but the price is right. Report
November 26, 201511 yr comment_63548 Nice job on those tenons. That piece is really coming together fast. Report
