February 28, 201214 yr comment_34336 Awesome work John, I love the look after the finish is on. It just pops Report
February 28, 201214 yr Author comment_34335 Thanks Randy, the finish was sprayed on and was three coats of shellac and three coats of General Finishes Enduro Var. The General Finish was a satin finish. It was pretty shiny with the shellac.John MoodySite AdministratorJohn Moody Woodworkshttp://www.johnmoodywoodworks.com Report
February 28, 201214 yr comment_34334 John,You use HVLP? And how do you thin the shellac? You make your own?Gene'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton Report
February 28, 201214 yr Author comment_34333 Gene I use a HVLP gun and I mix my own Shellac. I purchase the flakes from WoodCraft and use DNA. I mixed a three pound cut for the seal coat.Gene Howe said:John,You use HVLP? And how do you thin the shellac? You make your own?Gene'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton Report
February 29, 201214 yr comment_34332 Not to belabor this, but, I'm clueless about shellac and I'd like to use it.Is the 3 lb cut in DNA ratios/formula available? Do you mix it the same for spraying as for brushing? Why do you use it as a seal coat instead of just using a poly? Can you recommend any reading about uses? I know it's not a very durable final coat. Thanks for your time and sharing your expertise, John.Gene'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton Report
February 29, 201214 yr Author comment_34331 Gene, I will open another thread on Shellac in the Finishing forum. I think it might be a good discussion.John MoodySite AdministratorJohn Moody Woodworkshttp://www.johnmoodywoodworks.com Report
