March 7, 201214 yr comment_32947 I have a 4-jaw chuck and a collet chuck, but I'm still not convinced they are the best for roughing. Paul Krautman was/is a professional woodturner in our Showme Woodturners and he always starts with a face plate. When I was teaching in the '70's and early '80's we didn't have the fancy chucks yet, and we did all bowl turning with face plates and backing plates sandwiched with paper. We also used powdered resin glue for most of the critical glue ups. It rendered a fine brown glue line at times but no worries about heat build-up or moisture softening.Dan Coleman Report
March 17, 201214 yr comment_32946 John,Any updates on the first bowl or the second bowl?SQHappiness is wood chips flying! Report
March 19, 201214 yr Author comment_32945 First bowl went to the designer bowl firewood bin. The second bowl is ready to come out of the clamp as soon as I have a little time. SQ said:John, Any updates on the first bowl or the second bowl? SQ Happiness is wood chips flying! Report
March 23, 201214 yr comment_32944 Great job! Nice little bowl press jig. I made one of the collapseable bowls which was nice. I have been thinking of trying out one similar to what you are making but I have been getting my shop organized so haven't done much. Would like to see the finished product! Report
March 24, 201214 yr comment_32943 Looking forward to seeing it John! John Moody said:First bowl went to the designer bowl firewood bin. The second bowl is ready to come out of the clamp as soon as I have a little time. SQ said:John MoodySite AdministratorJohn Moody Woodworkshttp://www.johnmoodywoodworks.comJohn MorrisThe Patriot WoodworkerProud Supporter of Wounded Warrior Project and Homes For Our Troops Report
March 25, 201214 yr Author comment_32942 I have been running a bit behind John, I hope to get on it later this week.John Morris said:Looking forward to seeing it John! John Moody said: Report
May 19, 201214 yr comment_32941 Using the lathe almost seems like cheating... doesn't Rothman sand it all down? I don't have a lathe... don't have room for one and I never used one... but I figured out how to use the basic "bowl from a board" method that Rothman uses in her book (and many others have used before) to make things other than bowls ala Malcom Tibbetts. Spence Report
May 19, 201214 yr comment_32940 John,How is that second bowl coming along? Â I'm still looking forward to seeing it. Â SQHappiness is wood chips flying! Report
May 19, 201214 yr comment_32939 Spence,I started making the Carole Rothman bowl method when her first book came out but I used  a tilting spindle sander for sanding interior and exterior.  I finally got smart and put them on the lathe.  The lathe is so much easier.  I personally will never go back to doing them by hand.  SQSpence Bloom said:Using the lathe almost seems like cheating... doesn't Rothman sand it all down? I don't have a lathe... don't have room for one and I never used one... but I figured out how to use the basic "bowl from a board" method that Rothman uses in her book (and many others have used before) to make things other than bowls ala Malcom Tibbetts. Spence Report
May 19, 201214 yr comment_32938 I don't blame you... it can be a LOT of sanding. I'm envious that you have an easier way!! LOL Spence SQ said:Spence,I started making the Carole Rothman bowl method when her first book came out but I used  a tilting spindle sander for sanding interior and exterior.  I finally got smart and put them on the lathe.  The lathe is so much easier.  I personally will never go back to doing them by hand.  SQSpence Bloom said:Happiness is wood chips flying! Report
