Showing results for tags 'water leaks'.
  1. this is another yesteryear that was all face lift w/ rot at the brick elevation.. the T1-11 was poorly flashed letting water seep back into the rim joist and rotting it out.. the windows leaked so bad there was a perpetual breeze strong enough to blow out candles. here's the start... an over view of the finished project from the front... the triple window replacement w/ new headers and built mullions from Redwood... when the T1-11 was removed to fix the rot at the brick the bricks fell off of the house... the stays had rusted away... cleaned all of the bricks and put them back up... New OH doors w/ Redwood frames and Cedar facade... Revamped entrance... installed new door... overhauled backside w/ the same rot repair here too... also the new fascia and soffit.. gutters came later... cleaned up gable end w/ the swamp cooler relocated from a window to the gable and ducted through the house...
