Showing results for tags 'tri-square'.
Took a look at my Starret squares and found different markings for hardened on each. The 12" has hardened marked on the rule and the square frame but not on the center finder. The 6" set has hardened marked on the rule only. I know this is an original set for sure because I still have the box. The angle head has hardened marked on the rule only also. It is not stamped on the frame. I wonder if the hardened rules were used with the common sets but a true hardened set would have the frames marked as hardened too.
- 1 reply
- tri-square
- tri square
(and 3 more)
