Showing results for tags 'stanley?'.
I am trying to identify a plane I inherited from my Dad when he passed. The part on which the frog sits (is this called a boss?) is H shaped and has C 74 1/2 stamped on it. There is a 2 stamped in the base by the heel. A U is stamped on the frog on top and in the front, down close to the base. Made in USA in on the top of the base by the knob, and also on the iron. No markings on the cap iron. The sole is 14" long, with a 2" mouth. The only brass component appears to be the machine screw holding the tote to the base. The sole misses being square to the sides by maybe 1/32", but is flat along its' length, so if I am not using it on a shooting board, is this really an issue? I thought at first it might be an older Stanley, but my research indicated that the 74 was a floor plane, the only one they made for planing floors, with no mention of a 74 1/2, and actually nothing with a preceding C. Now I am thinking it is a cheaper brand that used a knock-off of the Stanley numbering system. Posting pictures now.
