Showing results for tags 'snow flakes'.
stack sawn 1/8" bb. 10" tall. I used 8 different air brushed water base paint colors. Took a few minutes! Used a piece of cardboard to color each side different. You can see the wood burning but as long as I can control the blade I never change blades especially if I color the wood. # 5 Flying Dutchman blades and water base air brushed for the color... Elmers yellow glue and two very small plastic clamps to glue the half pieces on. Very little sanding with these blades. One good amount of clear Rust- o enamel and while still wet sprinkle silver glitter, let dry and one more coat to lock the glitter in so mom won't raise ole billy s. The glitter does cause a mess so drop cloths is suggested.
- 11 replies
