Showing results for tags 'shelf life'.
Found 2 results
  1. PostalTom
    Glue shelf life
    Well, I found out the hard way that when a manufacturer puts a shelf life date on a bottle of glue, they mean what they say. I glued up a project using Old Brown Glue that had a shelf life expiration date of June 2020. I figured it's not that much out of date, what could possibly go wrong? I found out. I went down to my shop the next day to do some more joinery, and every joint I had just glued failed. I said "Oh darn". I got my temper tantrum out of the way, and decided it was time to grow up and fix my project. Reglued using Titebond, and so far, no problems. Of course, I had to clean up the old joint surfaces, so those joints aren't as pretty as they were, but this is for the shop, so I'm not that concerned with appearances. Just to be clear, I'm not knocking Old Brown Glue. The fault was mine, not theirs. I've used it before, with no problems. Lessons learned? 1. Believe the shelf life dates. They are there for a reason. 2. Don't buy more than you can use within that date, unless you are OK with throwing away the excess once that date has arrived. 3. Don't take out your frustrations on the project. It's not the project's fault either.
  2. Going to the store today, they had two cans of the finish I wanted. I know this product has a limited shelf life and I would span it over the next two or three large projects, so I wanted to make sure it was still fresh, and get the fresher one. At first, I felt little guilty digging out the fresher one. Then I rationalized: It's not cheating in games of chance if you know the odds and it's not cheating in the store if you know shelf life and to look for date of manufacture. It helps to go to a store that moves a lot of that particular product so you don't get one that's been sitting on the shelf for five years. It may depend upon the clientele more than the store chain. One big box or paint store might move a lot of a particular product while another version of the same store 50 miles away may not have any customers that buy it. Sometimes the dates are obvious. Sometimes they are encoded. Sometimes, they tell you the shelf life. Sometimes, they don't. A little knowledge here is your friend. Shellac and waterborne finishes have the shorter shelf life. Shellac starts a gradual degradation process called esterification. As it goes on, shellac will fail to cure to a hard finish. If you are mixing your own, try to just make enough for your current project or two. For home-brew, I generally start checking at about six months and really worry after about a year. I test before use by putting using some on scrap. If it's not cured in 30 minutes or so, it's past its prime. For SealCoat, whatever solvent mix they are using it generally lasts 3 years or more. Waterborne finishes are generally good for a year, but I've used them beyond that with success. Oil-based finishes are usually good for a long time, but in a partial can, they can start to cure and gel. Lacquer is good for a long time. Even glue has a shelf life.But they say that as long as it's not curdled, it's OK. Shelf life can be dependent upon storage, too. Store finishes in a hot garage all summer and they'll age faster. Store waterborne finish or glue in a freezing garage all winter and they're toast. My philosophy is that finish (and glue), when you consider wood, hardware, and time, is one of the cheapest parts of the project. And to recover from a failed finish (or glue) is a lot of work. It's not worth being frugal cheap here. When in doubt, throw it out. Or buy smaller cans to begin with. A gallon may only be two or three times as much as a quart, but if you throw 3/4 of it out, it's not a deal. Here are some more or less obvious manufacture dates . And some less helpful ones Sometimes the company web site will tell you how to decode, or someone else has figured it out. Google before you buy. More reading http://www.rockler.com/how-to/determine-wood-finish-varnish-oils-expired-extend-dispose/ https://ardec.ca/en/blog/11/how-to-prevent-finishing-product-leftovers-from-drying-skinning-or-hardenin Label decoding https://www.popularwoodworking.com/woodworking-blogs/flexner-on-finishing-blog/user-unfriendly-zinsser-bulls-eye-shellac https://www.homeownershub.com/woodworking/minwax-date-codes-543580-.htm Shelf life of common finishes http://www.finewoodworking.com/2013/02/07/all-finishes-have-a-shelf-life https://books.google.com/books?id=PRhOBQAAQBAJ&pg=PT1456&lpg=PT1456&dq=jewitt+shelf+life+finishes&source=bl&ots=HkMRmQenkY&sig=2TDrijvok3-qu20hBRWY_1D7-7g&hl=en&sa=X&ved=0ahUKEwiPxtWe9P3XAhUB1CYKHRUOACwQ6AEINTAC#v=onepage&q=jewitt shelf life finishes&f=false Titebond date shelf life and date codes (from their FAQ) What does the term "shelf life" mean in regard to Titebond Wood Glues? "Shelf life" is a conservative estimate of the minimum time period that we would expect a given product to remain usable, when stored as directed. This concept might also be called "useable service life" or "storage life," and it necessarily refers to both the physical handling properties and the ability of the product to perform properly. When used in reference to wood glues, reaching the stated shelf life does not mean that a product will "expire" or become unusable. Instead, we view the stated shelf life of most of our glues merely as a guideline to avoid potential aging concerns. In reality, as long as products like Titebond Original, Titebond II and Titebond III remain fluid, without a drastic change in appearance, they will continue to perform as intended. What is the shelf life of Titebond Wood Glues? Our literature states the shelf life of a majority of our wood glues as two years. Titebond Polyurethane Glue has a one-year shelf life in an unopened container, but is useable as long as the glue remains fluid. Polyurethanes, however, are designed to react when exposed to moisture. Sometimes, they begin to cure, and solidify, after the bottle has been opened. Most of our yellow and white glues, including Titebond Original and Titebond II, remain usable beyond two years. Should Titebond Original become thick and stringy, or Titebond II turn into an orange-colored gel, these changes signify that the glue is no longer usable. The minimum shelf life of Titebond III is stated as one two years. When stored appropriately at room temperature, Titebond III is expected to last beyond its stated shelf life. If thickened, shake vigorously by firmly tapping bottle on a hard surface until product is restored to original form. For a complete list of Titebond Adhesive shelf life click http://www.titebond.com/Libraries/LiteraturePDFs/ff876_ShelfLife.sflb.ashx. How Do I Read The Lot Numbers? Our current lot numbering system is a 10 digit code. The format is: aymmddbat#. The "a" stands for Made in the U.S.A. The "y" is the last digit of the year of manufacture. Digits "mm" represent the month, and "dd" represent the day of the month. The final four digits represent the batch number used for quality control purposes. Therefore, a product with the lot number A104270023 was manufactured on April 27, 2011.
