Showing results for tags 'sewing machine'.
I think this was a project that I got done during the blitz last year. Wife's sewing machine (well one of 8) is the one she takes out every week to a "sewing bee." It's a Singer Featherweight, ca. 1940 and is light and compact. Does a great job on basic straight stitches. Anyway, the old case was getting a bit ratty, so I made her a new one. One admonition, "Don't make it too heavy." So I ended using 3/8" q/s white oak. I tried doing box joints on the corners by my dado blade was not a true, even amount. And by the time I'd made 30 cuts, it had trouble aligning. You know, if you're off 0.0001" per cut, after 30 pins and 30 slots, you'd be off 0.006 and that's enough to inhibit a slip fit. So I put angle supports inside and keys on the outside.
- 22 replies
- sewing machine
- box joints
(and 1 more)
