Showing results for tags 'seam ripper'.
Found 3 results
  1. My Mom is 91 (this past Monday) and she still sews and makes clothes. I noticed she had an the same seam ripper for years so I thought I'd make her a new one for Christmas- but it turned out to be a birthday gift. However when making one it's just as easy to make two so the other one will be for my sister for Christmas. I bought the kits from Craft Supplies because I needed some other stuff that I can only find at their site. Making the rippers is pretty straight forward, especially if you turn pens. I had some walnut pen blanks I found in a box of scraps. Drilled them with the proper sized bit using the lathe. One trick when drilling pen blanks is to not drill the hole completely thru the blank. Using a brad point bit will have the point punch thru before the bit actually exits the blank. This process keeps the blank from being blown out when the bit would exit. Once the brass tube is glued into place, the end of the blank can be trimmed near the tube- I trimmed mine on the band saw. Then used the sanding center to bring the wooden blank flush with the brass tube on each end. I planned on doing a CA finish on these. To keep the CA from gluing the bushings to the blank/tubing I apply a coating of bumble bee butter to the bushings. Then mounted the blank and bushing to the pen mandrel. Then the assembly on to the lathe Rounded the blank with a roughing gouge Shaped with the skew Sanded the blank to 400 with Abranet mesh to 400 and finished off with Abralon pads to 4000. Applied some sanding sealer. Then about 40 layers of thin CA- Assembled the parts with my shop made pen press One gold and one silver I still have a bunch of wooden scoops to turn for the nurses at my doctor's office and a few other people.
  2. John Hechel
    Ripped some yesterday
    Played around a little with some seam rippers and pepper mills this week. Was a fun few hours of time. Especially because i didn't have a 36 mm drill bit so i had to custom grind a new tool to enlarge the hole from 1 3/8ths.
  3. Ron Altier
    Seam rippers
    When I made the last two ornaments out of orange and purple, I cut off some material with the bandsaw first. I glued them together and turned them round. My wife saw them and said they were perfect for seam rippers. They are now part of her collection
