Showing results for tags 'planer stand'.
I mentioned a couple of weeks ago after my 20 year old DeWalt 733 died that with the new DeWalt 735 I wanted to build a stand. Well, it is built and works just fine. I started out to build it entirely of Walnut but it turned out I didn't have quite enough on hand without getting into my good stock and I wasn't about to do that. So parts of it are Walnut. Here's the finished stand under my tablesaw extension - And here's the build video - Enjoy! David
- 11 replies
- dewalt 735
- planer
(and 1 more)
DESIGN & BUILD SOMETHING PLANNER IS MOUNTED TO PERMANENTLY. PUT FRAME UNDER THAT WITH HOLE THRU FRAME TO PASS A 2" PIPE THRU. OTHER SIDE OF PIPE ON FRAME WORK COUNTER WEIGHT TO MAKE TURNING PLANER UP & LATCHED IN POSITION,(no more picking heavy planer up) WHERE COUNTER WEIGHTS ARE WILL BE SMOOTH TABLE TOP, TO BE USED WHEN PLANER IS DOWN BELOW. Gentlemen be kind, i made thru 6th grade, Thanks, olbuck.
- 14 replies
