Showing results for tags 'paint thinner'.
- 1 reply
- mineral spirits
- naphtha
(and 4 more)
If you've got a "dirty" solvent, one used to clean brushes or spray guns, how do you get rid of it? First option is to re-use it. If you are using a paint thinner to clean brushes, just put a cap on it and let the solids settle out. I use a "toucan" system. Can 2 (that I mark as jar II) is the dirty jar, and the first rinse of the brush. Jar I is the cleaner jar and used for the second rinse. When jar II gets so full of solids, it's not effective, I let it settle and pour off the clear to jar I. Then I mark jar I to jar II (just add an I) and it becomes the first rinse jar. Then I get a clean jar and fill with fresh paint thinner and it becomes jar I. Similar process to clean spray guns used for lacquer or shellac. Except the gunk does not settle out to the bottom, so proceed to next step after a number of uses. Second is to discard it. Local laws vary a lot here, so check to see what is legal and illegal. If your community has a hazardous waste collection day, that's a good choice. You can put the solvent/thinner/gunk in a jar and let the volatiles evaporate away. Put it somewhere where it will be protected from weather, away from kids and animals, but gets some fresh air. It can help to add in a bunch of sawdust to increase the surface area. Once turned to a solid, you can dispose of in the trash. You can use this technique to discard old, expired, or unused finishes, too. If you have a spray gun, you might spray the solvent to let it evaporate away. Really no different than spraying the finish and having the solvent flash off. Don't just pour down the drain. (short and simple this week -- I was away all last week)
- 10 replies
