Showing results for tags 'oct 21st'.
  1. A busy week in the shop which was a nice change. Got a lot of work done and still a lot to work on. I got the moulding cut and installed on the Poplar plant stand for the customer and they approved this is what they wanted. So now for a final sanding and then Ebony Stain. More pictures as it gets closer to finish. Also got the Poplar frames cut out for the screen door and ready to cut mortise and tenons on them. I got started and have part of them cut but had to pull of to work on another order. Also got the Walnut Bistro table top cut to size so I need a final sanding on it and them a finish applied. This weekend it going to be mostly sanding and finishing. Also glued up blanks to cut out 36 cheese boards to finish on order and start on another one. Only so much room to stand them around while glue tries. But I got them cut into boards, so now they get a final sanding and them oil applied. Pretty much been my week and as I said the weekend will be mostly sanding and finishing. I do have a gun shop to go to on Saturday for a little while but then it will be back to the shop and back to work. Hope you all have a great weekend and get to spend some time in your shop, We here at TPW love to see and hear about all the projects you are working on so share with us your weekend agenda. Weather it be woodworking or whatever we love to hear what you are doing. I can hear that ROS calling my name so I am off to sand!
