Showing results for tags 'music stand'.
I have a question for you all. I am in the planning stages of building a music stand, I like the simplicity of this Maloof stand. One of the design areas I'd like to use is the arm and sheet/book music support part of the design. I can't see how the arm is staying in place, could it be as simple as gravity? The weight of the left side of the arm is heavier than the right side, so it's pinching on the vertical post as it rests? There isn't any obvious screw handle or clamping mechanism holding the horizontal assembly up and in place. I am assuming the height is adjustable? Thanks for any opinions on this.
- 11 replies
- maloof
- sam maloof
(and 5 more)
