Showing results for tags 'machines i use'.
  1. You can see by the lack of dust I keep it all going outside... Well sometimes I do forget to turn it on but it does work good once it is running.... Doc keeps tell me I am in good health.. I tell him I keep the bad stuff away with the layers of saw dust and he says well don't do anything differently and I say this has been going on since I bought the first table saw in 1960 a few days after I got out of the army... Good for you, he says... Sometimes I have to push some of the dust out with the Nasal Spray which is the only thing I ever use and is all I ever use in the winter with no down time..I don't guess I ever had the flu come to think of it... When I am cutting small pieces with the bandsaw I slide a piece of 1/4" BB under the fence past the blade to keep them from dropping out of sight. For those of you who are afraid of a little dust just pretend you can't see any and all will be okay...And no you don't have to go see your srink to get you straight again... I use 60 grit on the disk and the belt sander.. best grit for fast removal...60 grit on the 9" drum also.. The picture of the upside down hand sander is exactly how I use it on the picture pieces. Nothing works better for what it does!
