Showing results for tags 'liquid hide'.
Folks, I was perusing one of my favorite woodworking tools sites, and found a bottle of glue, liquid hide. I have always known about liquid hide, or hide that you would heat up in a glue pot, the one benefit I always knew about was you can repair work that was joined with hide glue, you can heat it up and the joint will release and repairs are possible. One of the benefits I did not know about, is this quote: Doing some more indepth research I found that while it's always a good thing to clean up the glue from the surface of your work, if you miss any with hide glue, it does dry transparent, and as long as you are not using stain, but a clear type finish, it's really no worry as the dried hide glue blends very well with natural wood and natural finishes. It also sounds like there is a much longer open time for assembly, in chair making that is a very desirable benefit, getting all those parts coated and assembled can be stressful. All that being said, does anyone else have any experience with hide glue? Benefits, pitfalls? Here is the glue I was previewing, a bit pricey, but perhaps hide glue just is. Oh ya, one more thing, with this liquid hide glue you don't have to worry about glue pots, since it's already liquifide. Here is the source I am reading about now: https://www.toolsforworkingwood.com/store/item/MS-OLDBROWN.XX
- 7 replies
- glue
- liquid hide
(and 1 more)
