Showing results for tags 'grout sponge'.
I spent about 4 hours yesterday wiping stain on three cabinets I'm building. I think there's about 7 sheets of plywood in there, plus some trim, and both insides and outsides and lots of little corners. I usually wipe on stains with a rag. That was working, but some of the surfaces had to be one vertically and there were lots of drips (luckily I had rosin paper and drop cloths down). To get into the concave crevices I finally got a foam brush. And about half-way through, I just started to use it on the vertical surfaces as it seemed to go faster. and fewer drips. But by the time I was done, it was pretty much shreds. While cleaning up, I remembered a tip to use a piece cut off a grout sponge. Duh! I had those in the next room where I keep finishes. I've used this for applying dyes but not for pre-canned stain. I'll remember that next time and save myself a lot of time and mess.
