Showing results for tags 'counter top'.
Washer Score Tip (Custom Cut Counter Tops to Wall Surface)
John Morris posted a topic in Woodworking Tips
I found this great tip on Facebook while perusing other woodworking venues. Here is a neat little trick to scoring a counter top to the wall. Using a washer, to smoothly ride along the imperfections of the wall. The photo says it all. This tip could be used for many things, not only counter tops.- 17 replies
Tonight after work I got the two panels sanded on the drum sander and ready to glue up. I need to pick up some couplings so I will have plenty of long pipe clamps. I should be able to get it glued tomorrow night and then clean up the joint and oil and sand it smooth. It is coming along and those two panels were heavy, When this is finally one large panel, it will sure enough be heavy. After it is cleaned up, I will cut to size and round over all of the edges.
- 1 reply
- counter top
- block
(and 2 more)
