Showing results for tags 'case work'.
Found 2 results
  1. steven newman
    First Project of 2025
    Could have sworn I started this a while back....oh well.. Seems I was getting tired of getting poked with chisels, while reaching for a plane.... And this rack was a bit too long.. To be swinging on just that single hinge...time for something different to be made.... So...this will get a make over....went out and bought a few thin planks of KIWI Pine... Clamped this flat for a few days...KIWI Pine? Next item...was to work on that old rack a bit... Set this aside for a day....and figure out where to make a few cuts... Had too many slots, anyway...only needed 11....Mitersaw next.. Racks were a bit too thick...resaw one side a bit, trying to avoid all them screws.. Once these were removed, I could remove the counter bored strip, and a matching strip from the other edge.. The face I did not resaw, needed leveled a bit Test fitted a few of the larger Mortise Chisels.. Square is showing where I needed to trim this rack for length, as there was one too many slots...the narrow chisels? Seem to be flopping around in the slots....we have ways.. 1/2" forstner bit...just enough for the chisel's bolsters to fit in. with come back later with a countersink bit, to accommodate the socket chisels... Problem...as this will be attached to the back of a case, and NOT swing out, needed a way to reach into the case and pull a chisel straight out, which is why those slots were opened up But, how to keep the chisels in place? A Hinged "keeper" should do the trick... so.. Racks are almost done...Need to build a box/case to hold them. Stay tuned...
  2. steven newman
    Adventures in Pine
    Ok, This is a mess.. And so is this.. Broom is needed.. Both here, and the work area.. Fancy planes have to be put away.. And closed up to stay clean.. As for that Messy Bench? "Clear For Action!" Take a good look, as it won't stay like this very long.. Pine that is available right now? Needs a Project?...Maybe build a case for... With this as a "Tool Kit"? Very Interesting Maybe I can get two people to try to get this.. Up to the Fire Pit? Yeah, right... Will leave these for later.. Panels to make bottoms for Cases... Stay tuned...
