Showing results for tags 'brace and bit'.
  1. Got home with a stack of forms, to apply as a "First Families and Pioneers of Logan County, Ohio. May take a week to complete those...All the way back to the 1800s when Ohio wasn't yet a state.. Got bored (dangerous) so headed to the shop to putter around....decided to make a bunch of lines on some pine scrap. One of the lines was a circle...took that to the bandsaw.. Meh, will just have to do. All the other lines were for either a hole, or not a hole..next, decided to drill a few of the holes...drill press was set up for rehab work.. We have ways.. Drill down until the tip pokes through, then flip the blank over.. Finish the holes, then the chisels took over... The reason for those two clamps? Seems that big Japanese mortise chisel caused a split....I cleaned things up, apply the glue and clamps, and kept on chopping.. Until the clamps got in the way....narrow chisel was powered more by my chin, than the hammer. Will let the glue set overnight, then try some more.. Maybe call this The Trouble with Trivets? Stay tuned...
