Showing results for tags 'birch bowls'.
  1. AndrewB
    Birch Bowls
    I'm not sure if this is the right way of doing things but the birch bowl that I started working on yesterday.... I started hollowing out today. I took the outside walls down all the way to about an 1/4th an inch or thinner. I still need to hollow out the bottom I've still got about an inch of material left to work with. I wont be taking it too much deeper because of the risk of blow through. Not sure if this was wise or I should have left a little more material in the long run or not. But hopefully this one will turn out nicely.
