Showing results for tags 'air diaphragm'.
  1. I have an old Delta 40-560 scroll saw. The air diaphragm, or bellows, that generates the air flow to keep the cut line free of dust is shot. I can't find a replacement for this part anywhere. I emailed Delta, but they don't have a replacement. They recommended I check with another company that specializes in obsolete and discontinued parts, but I struck out there. So here is my question. You know the flex seal product, where the pitch man sticks a patch on a leaking 5 gal bucket of water, or cuts a boat in half and then fixes it with the tape version of this product? Would that fix the bellows on my scroll saw? I'm thinking of a quick dip in a can of this stuff, or maybe painting a layer on the bellows with an acid brush. I use a scroll saw so seldom that a purchase of a new one, or even a used one, just doesn't make sense. Everything else works fine. I can use it this way if necessary, but after a while I get dizzy from trying to blow a steady stream of air so that I can see where I am cutting. Any suggestions?
