Showing results for tags 'air compressor'.
Found 5 results
  1. I normally stick to the wood turning forum but I just had an unbelievable customer service experience and wanted to give kudos to the company. I bought an "Industrial Air" compressor at a local farm store in 2012. About a year ago the head gasket went so I bought a 3rd party rebuild kit and replaced it. Well, it blew again this morning. Rather than keep replacing it again and again I wanted to see if a new pump was affordable. Called the 800 number on my owners manual and the lady found what I needed and said they have it for four hundred(about) dollars. She then said, here is a company that has it for $360.00, hang on, Oh here it is, "Air Compressors Direct" has it for $259.00 and here is the model number they have it under. Unbelievable to me. What great customer service. Just ordered the pump and BTW, free shipping to boot
  2. My compressor is an 80 gal. upright with a petcock water drain at the bottom. After every day's use, it gets drained...religiously. As I age, it gets more difficult to get up and down to do that job. My son took note of that and, designed, built and, installed an electric drain valve. The switch is in a magnetized box that is stuck on the side of the compressor. He installed it yesterday and, it works like a dream. The old back and knees are extremely appreciative.
  3. Stumbled across this on Facebook. I bought a little compressor to drive the Pneumatic nail gun I bought to build the shed I just poured a slab for. I think this is a fabulous idea and I'm going to build one but it needs much much much bigger wheels to be trundled across my redneck rural yard out to the back of my pool every day. A couple of scrap kid's bicycles should provide the needed wheels.
  4. Smallpatch
    Gene Howe
    Hey I don't want to suggest something you might not want but for what you suggested you are in to, an air grinder should be considered if you have a reasonable sized compressor and not the screaming kind. Because die grinders take 1/4" bits they can hog off more material than the 1/8" bits I prefer on carving. Also Wood Carvers Supply has the bits in 1/4" size and will do the same as the 1/8" bits I use but much faster.. Also if you don't have yet, Bring up Wood Carvers and check out their 2" carbide nugget wheel # 264866....and hold on to your hat for it will throw wood all over the place..Also a chain saw wheel will get after wood real fast but it will do the same to skin and bones the same way!! I can trust their air tools way more than their electric models. I have maybe ten different HF air tools and only one electric and all they need to last a while is light weight oil... But you do have to be careful about the amount of oil when used around expensive wood.. These have front and also rear exhaust so the rear exhaust model would be the one to buy. The last two I bought from HF is their 13.99 and the 19.99 1/4" angle grinders ...They also have the small 5/8" diameter pencil grip size air grinder for 1/8" bits and will be the next I buy..24.95 and will be cheaper with that always 40% off of any one item.
  5. Grandpadave52
    Saturday Pick & Run
    Late getting round tuit, but last Saturday I saw a Yard Sale listed on CL not too far from home. The main items shown that I had interest were two portable air compressors, both old style oil pumps; one electric, one gas. My well over 40 y/o Sanborn? died a few weeks ago. So, off I went...Saw only one air compressor sitting in the yard which appeared to be a home shop conversion; As customary I wander around to see what else is there first. A table with a couple of big boxes full of "tools" mostly marked $1 that appeared this had not been their first yard sale appearance. Thanks in advance for looking. Comments/questions are always appreciated. Don't forget to pick-up your candy wrappers & drink containers at the end of the tour. Anyways here's what I came home with... Top turned out to be a Central Tool (not H-F) pen vice; Next two are ratcheting, fixed shank Phillips screwdrivers similar to Stanley's; more on those down the line Bottom is 3/8" socket wood chisel. Pen vice is a tad crusty...will it clean up? Stay tuned... Wood chisel is a bit crusty as well but under the rust I found Ben Hur and underneath that is USA. The best I can determine so far, Ben Hur was an in-house branded name of the old Van Camp Hardware & Iron Company, Indianapolis, IN Interesting they (Van Camp)were able to trade-mark the brand; Our County seat is home to the General Lew Wallace, the author of the book, Ben Hur The two screwdrivers; both are marked the same, Model 527 and that little tri-angle, Manufacturer Steel Corporation, Germany, U.S. Zone. With that mark, these were made sometime between 1946 & 1954 in occupied Germany. the two are identical except one had what appears to have been a red lacquer painted handle, the other black; the tip on this one looks more like a #2 Phillips where on the other more pointed like #1 Phillips.. This one appears to have suffered a bit more and actually appears to made inferior to the above one. Oh, the display table...not that I needed it but...A Black & Decker 425 Workmate...top is not the multi-layer ply nor the frame aluminum. but it does have the fold over front vise to act as down clamp. Oh yeah, why did I go there looking? Turns out this was a from the factory 5 HP gas powered, twin cylinder, single stage Speedaire (Grainger in-house brand)...guy said it will start-up on first pull... dang, it did too...pumped up, has the pneumatic governor pressure switch which works; while running I open the tank drain, no moisture, rust, or anything discharged...he had replaced one wheel and had the other yet to put on So I never had saw a price on the A/C until we loaded it ($150); he told me initially he would take $100; Workmate marked $25, (4) tool items = $4. I offered $100 and he helped me load I plan to take the electric motor, pressure switch, etc. off the old Sanborn and swap to this unit; will then convert the Sanborn tank to auxiliary surge tank (tank was replaced under a Sanborn safety recall maybe 20 years ago) As for the other items refurb mostly done...sorry lighting was not so good; what appears to be rust is reflection from my red/rust colored t-shirt; still need to sharpened the chisel but my honing guide needs refurbed too I may just clear coat the handles leaving the that much original...depends when I get some more round-tuits Once cleaned up, both shanks have R (backwards) 7? C (backwards) 7? - SS 2; sorry for the blurry picture
