March 18, 201412 yr comment_4059 Took a bit today, to assemble the parts, and fit things into the tool chest. Tray turned out a bit wider than needed. Lumber was a bit thicker than needed to be. had to cut a rebate along the tote tray's side, to allow the tray to sit down in the chest. Next time, will use a thinner stock..( and there seems to always be a "next time") Ok, a look or two of the completed tray, all nestled into it's new home I suppose I had better hide than level, before Moody shows up. A view from the other direction I think this chest is getting ....almost full nah, I think i can fit a few more things in there... Report
March 18, 201412 yr Author comment_4065 This keeps up, I may have to build a second tool chest..... Thinking of adding a few rods. The kind used on cantilevered tool boxes, wher you open the lid, and the tray would swing up and out. Not sure IF it is do-able, will look into it.. If you look closely, you might see a few tools you will recognize....Like a Stanley SW#103...... Report
March 18, 201412 yr Author comment_4062 I suppose I could fasten all three together, into a single tote? Might need to make a few brackets under the chisel tray, though. There are two chisels that may not fit in the trays, though. Yep, that is a full sized note book. The corner chisel is 7/8" , and the regular one is 1-3/8" wide. Just a couple "small" chisels. Think they might get lost in the tool chest?? Report
March 18, 201412 yr comment_4061 looks good Steve. however you'd be surprised how well those large chisels can hide Report
March 18, 201412 yr comment_4060 Just don't let them get to know the Pencils. They will really be good hiders then. Report
