38 minutes ago38 min comment_383151 Hi I am making a hoosier cabinet lower attached for my spouse and there is a top and bottom and a divider and two sides plus a back for the glue up.I can sub assemble the top D2, bottom D2, divider D3 with a spacer block to keep everything level because the sides are not done yet.They are awaiting my router which is being repaired.The design wants it all glued up at the same time and the back D4 inserted to square up the assembly. But I see no harm is gluing up this sub assembly which are tight fitting dado work for plywood width x 1/4" deep.I do not see why I cannot glue up the divider and the botom/top plates do you see any problem?the divider is 13.5" in from the end of the top and bottom plate rh edge with the spacer placed near the end. Report
26 minutes ago26 min comment_383152 I think it's doable. The spacers would keep things "level" but you will also need to be sure that part D3 is "perpendicular" to the top/bottom. That's probably why the recommendation for assembling all at once. Report
