  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
Estimating wood requirements
This is specifically for scroll sawing, but can also relate to general woodworking. ๐Ÿ˜€
My question is about estimating the wood requirements for more complicated patterns/projects such as fancy fretwork grandfather clocks; that is total wood needed on hand to complete the projects, including waste. I know we can nest patterns within the project wood, but there will still be waste, and in the case of hardwoods ( as opposed to Baltic Birch Plywood ) defects, such as knots.
I can google with the best of them, so I'm looking for practical experience in the answers. TIA. ๐Ÿ˜„
An example of nesting patterns with other patterns:
28 minutes ago, lew said:
Maybe someone in the CNC forum can provide some insight.
@4DThinker is pretty active over there.
But this is for scrolling Lew๐Ÿ˜
I don't think there's a direct answer for this. You just have to play around with the arrangement. I suppose you could use something like Sketchup.
I think one of the big factors is grain, which may take priority and create a lot of waste. For example, following a curve with curved grain rather than just randomly orienting patterns with the only regard being efficiency.
This doesn't apply directly but is an example of what I'm talking about. The doors will be arched. So I thought it would look good to have the grain follow the curve. Looking, and looking I came across a board that would work.
I don't do a lot of scroll sawing, but I would suppose this could take a project up a notch?
Recently Browsing 1
  • Robert Engel
  2. Tap Permissions โ†’ Notifications.
