11 hours ago11 hr comment_382671 A number of years ago, I bought Lee Valley's Veritas Micro-Adjust Wheel Marking Gauge. I even made a box for it. Wanting a couple more, I thought it would be fun to make a set of my own. One is out of Pine and the other two out of White Oak. But I really like Lee Valley's.So as time went by I decided that having one was not enough. Resetting it for various markings became a chore.So I decided to get a couple more Marking Gauges.I decided to buy another one like my first but also buy a Lee Valley Dual Marking Gauge as well. In addition, I bought the Veritas Shaft Clamp. This shaft clamp is a must. It makes no sense to buy the dual gauge without it.Then a few days after getting and using them, I decided they needed a box to store them. Like I did with my first one. However, I decided to make this box to house both gauges. They will be placed into recessed cavities.First, I arranged a few boards on my bench to get an idea of box size, etc. for the two new gauges.Then I used Sketchup 2017 to draw the gauges outlines. I then printed out an othographic top view of each gauge.After figuring out what the box's bottom size would be, I placed the printout on it to make the recessed cavities. I also save a copy to make the velvet inlays for each cavity.From left to right you will see the progressive steps.Next it was time to make the rest of the box. I decided to make the side corners all dovetailed. Handcut of course.Here is some of the work in process.After the box is all glued up, I run it through the tablesaw to separate the top and bottom halves. On the top, I cut a "Classic Ogee" perimeter profile. Next, I installed brass hinges.After sanding, I give everything a couple of blonde shellac coats.Next, I do the blue velvet inlays for each cavity. The marking gauges look good in their places.Here's the finished box!Thanks for Looking!Cheers!MrRick Report
