Posted
For a full run down on this project and rules please go to: The Patriot Woodworker and MWTCA "What's It" project
Additional What's It Rules
  • Unless you are completely sure what this item is, please avoid "definitive statements" that appear that you are without a doubt claiming that you know what the item is. For example stating, "this item is called a "widget xx" used for "insert purpose here". If you are making a definitive statement you must accompany your statement with evidence or proof from a secondary source.
  • An example of acceptable statements within the realm of having fun and educated guesses would be something like this, "I believe it could be", or "It appears it's made for this or that", etc etc etc...
Project Details
The information provided hereon is all the information that is provided, no further information on this item will be added.
Mystery Machine
Image Credit TATHS
I found this What's It at TATHS website, a wonderful website for the tool fanatics, MWTCA is running short on What's It's so we are resorting to other resources, thanks TATHS!
Posted
Yep  the two round things look like solenoids but where is the motor?
Posted
Transmission from an arcade sized Jack in the Box.
  • Haha 4
Posted
1 hour ago, Ron Dudelston said:
Powered by a hand crank.  Geared low too.  It does look like there are two capacitors but what’s the purpose.  And what’s up with the pintle wheel?
Nice obs there Ron!
  • Like 2
Posted
34 minutes ago, steven newman said:
Power feeder....
Could be! Now what's it feed,
  • Like 2
Posted
38 minutes ago, steven newman said:
Power feeder....
For what?
  • Like 2
Posted
Steve,it does look like an indexing unit of some sort and there is something missing.  The small cog between the crank wheel and the pintle is focal to the machine.  The pintle wheel keeps it from reversing.
Posted
Maybe feeding  a Molder Machine......Mortising Machine.....Drill Press...
2 "Capacitors"..might be solenoids, as there is an electrical junction box below them....
  • Like 3
Posted
Solenoids for a counter?
  • Like 3
Posted
Looks like processing equipment for farm use to me.
  • Like 3
Posted
See those grabbers, they were pulling or pushing something, could this have been the drivetrain for a conveyor system?
  • Like 3
Posted
Is this a push pull type of handle? Like to engage and disengage the movement?
Posted
Trace that spring down under...where it connects to the levers that are operated by the 2 solenoids..Solenoids seemed to be connected to the large gear...maybe to advance the product going through?
Methinks that the "crank" handle is more to "Start or reverse"  ...maybe to "reload" the machine...
  • Like 4
Posted
Steve, I see your logic and don’t disagree. If the crank is for start or reverse then you would have to be able to disengage it.
Posted
That cogged wheel in the middle...perhaps a drive belt to fit around it...and this is just the "Transmission?   With the clevis Morris pointed out as the gear shifter...or else a link to another machine?
  • Like 2
Posted
I don’t think that is a drive wheel unless it is a link belt because it is captured by the bearings.  No easy way to replace it.  To John’s point, that center cog may be the focal point of the machine.
  • Like 2
Posted
Guys, look right next to the indexing pintle…. There’s smaller, finer toothed pintle there.  I would pay good money to look under it.
  • Like 2
  • Thanks 1
  Only 75 emoji are allowed.
