Ron Dudelston Posted June 11, 2025 Report Posted June 11, 2025 Folks, I’ve made and sold a ton of cutting boards and cheese slicers over the years but I’ve hit a snag. I’m building stock for the 2026 Christmas sales and I decided to mix up my inventory of cutting boards by buying some acrylic templates and make some with fancy smancy handles. I’m having mixed results because of router bit grab and tearout particularly on the inside of the handles and it has to be the bit selection. I’ve used 2 fluted flush trim bits, spiral up feed flush trim and even compression flush trim bits. I’m ready to buy a new Whiteside 2 fluted 1/2” diameter, 1/2” shank but I thought I would reach and ask for your input. Grandpadave52 and lew 2 Quote
Fred W. Hargis Jr Posted June 11, 2025 Report Posted June 11, 2025 Maybe instead of the bit, it's that particular plastic??? Maybe a different kind would work better and still meet the requirements you have? just kind of thinking out loud. That said, I think the 2 flute would be better, but one with a shear cut instead of the straight up/down flutes (if that's what you tried). Grandpadave52 and lew 2 Quote
lew Posted June 11, 2025 Report Posted June 11, 2025 Don't shoot the messenger, but I guess you have trimmed away the waste on the inside of the handle hole and around the the perimeter. Grandpadave52 and PeteM 2 Quote
PeteM Posted June 11, 2025 Report Posted June 11, 2025 I was doing curved surfaces some years back and noticed that tearout and even wood disintegration would occur. I think it's the change of grain direction that throws me. I found that very light cuts were necessary, and in particular a final "clean up" shave helped. Grandpadave52 and lew 2 Quote
Ron Dudelston Posted June 11, 2025 Author Report Posted June 11, 2025 Fred, I used 3 o 4 different styles of bits with marginal results. The plastic template is 1/4” think and I nail it down with double backed carpet tape. Lew and Pete have carnal knowledge of the process because you have to trim the openings back really close to the template line and take baby cuts. Cutting with the grain is fine but the end grain makes your sphincter pucker. Grandpadave52 and lew 1 1 Quote
Fred W. Hargis Jr Posted June 11, 2025 Report Posted June 11, 2025 What about climb cutting??? kmealy, Grandpadave52 and lew 3 Quote
HandyDan Posted June 11, 2025 Report Posted June 11, 2025 Routers are my most hated tools. I never could get a satisfactory finish either. I feel for you. Grandpadave52, lew and Fred W. Hargis Jr 3 Quote
Danl Posted June 11, 2025 Report Posted June 11, 2025 My Opinion: Use a 1-1/2" dia. compression bit with bearings on both ends. Use double sided tape to adhere the template to the wood. Read the grain direction and use both ends of the router bit (top & bottom). The larger dia bit should result in a smoother finish and having two bearings will allow you to flip the board so that you are always cutting down hill. Infinity tools sells a bit(s). Danl lew, Grandpadave52 and Fred W. Hargis Jr 3 Quote
Danl Posted June 11, 2025 Report Posted June 11, 2025 (edited) 18 minutes ago, Danl said: My Opinion: Use a 1-1/2" dia. compression bit with bearings on both ends. Use double sided tape to adhere the template to the wood. Read the grain direction and use both ends of the router bit (top & bottom). The larger dia bit should result in a smoother finish and having two bearings will allow you to flip the board so that you are always cutting down hill. Infinity tools sells a bit(s). Danl Oops, I see the 1-1/2" dia is too large for the handle hole. Suggest using the 3/4" dia bit for the handle hole. Edited June 11, 2025 by Danl Gerald, lew, Grandpadave52 and 1 other 4 Quote
Ron Dudelston Posted June 11, 2025 Author Report Posted June 11, 2025 I thought about bumping up to 3/4. That would increase the surface speed. Grandpadave52, lew and Fred W. Hargis Jr 3 Quote
Danl Posted June 11, 2025 Report Posted June 11, 2025 Good set-up does not remove the pucker factor. Danl Grandpadave52 and lew 2 Quote
Wichman3 Posted June 11, 2025 Report Posted June 11, 2025 I'm primarily a scrollsawer, so you know where my mind went first. But, how are you roughing out the interior cut? Is that method tearing the grain of the wood so that when you go to finish the cut, the wood is already torn? lew and Grandpadave52 2 Quote
Ron Dudelston Posted June 11, 2025 Author Report Posted June 11, 2025 4 hours ago, lew said: Picture of the problem?? I wish I could. Luckily, the boards were large and I could salvage them and the evidence is in the burn barrel. Gerald, Grandpadave52, Fred W. Hargis Jr and 1 other 2 2 Quote
Ron Dudelston Posted June 11, 2025 Author Report Posted June 11, 2025 3 hours ago, Wichman3 said: I'm primarily a scrollsawer, so you know where my mind went first. But, how are you roughing out the interior cut? Is that method tearing the grain of the wood so that when you go to finish the cut, the wood is already torn? Actually, I am cutting them out with a scroll saw. Wichman3, lew, Fred W. Hargis Jr and 1 other 3 1 Quote
Popular Post HandyDan Posted June 11, 2025 Popular Post Report Posted June 11, 2025 I would then use oscillating spindle sander to finish them and cut sharp edges with sandpaper. Headhunter, Grandpadave52, Ron Dudelston and 2 others 5 Quote
Wichman3 Posted June 12, 2025 Report Posted June 12, 2025 7 hours ago, Ron Dudelston said: Actually, I am cutting them out with a scroll saw. So... next question about the SS blades. Flat or spiral? Size and type? Grandpadave52 and lew 2 Quote
Fred W. Hargis Jr Posted June 12, 2025 Report Posted June 12, 2025 Did you decide to not get the 3/4" bit? Grandpadave52 and lew 2 Quote
Popular Post Ron Dudelston Posted June 12, 2025 Author Popular Post Report Posted June 12, 2025 55 minutes ago, Fred W. Hargis Jr said: Did you decide to not get the 3/4" bit? I have ordered the bit, Fred. I think the key is to minimize the stock removal. That is, trim close to the line. Grandpadave52, lew, HandyDan and 2 others 5 Quote
Popular Post Ron Dudelston Posted June 12, 2025 Author Popular Post Report Posted June 12, 2025 5 hours ago, Wichman3 said: So... next question about the SS blades. Flat or spiral? Size and type? I will use a flat, very fine. Gerald, lew, Fred W. Hargis Jr and 2 others 4 1 Quote
