March 3, 20251 yr Author comment_352983 It says right on it A7&1/4 inch. I just could not see it because all of the writing was too small I used my cell phone to magnify and it was all the information was right there. I'm sorry to bother everybody but I do appreciate all of your help. Edited March 3, 20251 yr by Handfoolery Report
March 3, 20251 yr comment_352989 1 hour ago, Handfoolery said: Model number is ts11 43L. I will look that up and see what it is thanks guys. Link to manual- https://www.manualslib.com/products/Ryobi-Ts1143l-5143826.html Report
March 4, 20251 yr comment_353053 That's a tile saw blade alright. Looks a bit worn on one side more than the other, but still ok probably. At 7 1/4", you need to watch what blade you put on it. You don't want a blade with an aggressive hook angle like the average framing saw blade has (+10-20 degrees). I want to say a good crosscut blade will have a 5 degree or less hook, but I've had sliders for so long now I don't really remember. Stay under 10 degrees and you should get an ok cut. Negative hooks are sold as "fine finish" or whatever, but I never noticed much difference as long as it was a small number, + or -. My main slider is an old 8 1/2" Hitachi, and the only 8 1/2" blades I've ever seen are generally made for that saw, so I got out of the habit of paying attention to specs. Friend of mine had a smallish radial arm saw once, and he put a framing blade on it. That was an interesting experience - had to hold the saw back making a crosscut. I stalled it once too when it ran up onto the board and got wedged. That thing was a finger wrecker if I ever saw one! Report
