Posted
1 hour ago, lew said:
That is eye opening. I'm really surprised at the miter joint!
Yes, me  too.  The picture showing the spline was running across the joint (not in the finished joint, that I typically call a "key").  They did not test, but showed a triangular piece across the back, sort of making it like a half-lap.  They thought that would be even stronger.  That would be very easy to make on a table saw.
The other thing they mentioned is some joints are self aligning (e.g., mortise and tenon) and others require clamps in several directions (e.g., half lap joint).
In the text, they did warn of  wood movement over time potentially affecting the joint.  IMO, that's also an issue with dowel joints.
They also said something I say often in that some joints are strong enough for their application.  There is a big difference in requirements for a chair joint vs. a picture frame joint.
Posted
For sure.
  • Like 1
Posted
How were the stress tests performed Keith? With two pieces of wood, or all four pieces of a frame glued up?
  • Like 2
Posted
  • Like 3
Posted
8 hours ago, John Morris said:
That's kind of what I figured. I really dislike that test. It's not practical, nobody builds anything like that. Not trying to be combative Keith :)
Yeah, I tend to agree with this, but at the same time there are limits on the practicality of making a test realistic.  Testing a frame in the same way multiplies the time involved in making each sample by 4, and if they are doing a reasonable number of samples per joint (say 20 at a minimum) then the time required is going to add up pretty fast.
  • Like 3
Posted
Agree JWD. To be truly statistically sound, the sample size per joint type should be at minimum 31 all pulled at random from much larger lot sizes. Not practical for what they were trying to do. Their data is gives some insight, but not credible enough to conclude one joint is superior to others IMO.
Posted
If you build something correctly, it shouldn’t be under any stress to matter. A chair can differ..
  • Like 3
Posted
That is very true to a point, but just wood movement along can cause enough stress to have a failure. IMO
  • Like 4
Posted
Butt joints on drawer generally work find for most of the world..
As far as strength tests…. I have fought with woodworker on numerous forums that say that a Domino is as strong as a M&T. They are pulling a Trump and say it is anyway, when ythey know it isn’t..
  • Like 3
Posted
7 minutes ago, kmealy said:
This is a common stress on chair and table legs.
I'm sorry Keith, didn't see where it said the test was related to chairs and tables, I guess I didn't read far enough, but I'm not very observant at time either.
I thought the test subject was a frame sort of structure, since we are using 3/4 lumber in the test I think? A mortise and tenon joint in a chair done well using say 8/4 lumber, and pinned or drawbored is different than a frame type of joint. But I get the jist of the article. I enjoyed it, thanks for sharing Keith.
  • Like 4
Posted
If you look at the left edge of the first photo, you can see a small part of the information about why they tested this (you will see stress applied to a table leg).
  • Like 3
Posted
I'm not a huge fan of biscuits, but I have found uses for them.  I had an old crappy biscuit joiner when I lived in Tucson, got it used from Kent's Tools, and sold it there again when I moved in 2005.  Never replaced it, there's always another way to do anything in woodworking (if not 12 other ways!) so I just never made it a priority.  I did find half a dozen biscuits in a bag the other day, looking for the bag of 1/4" dowels.  Couldn't find those so I used 3/8" and broke the jig I was making as I enlarged the hole.  The dowel was a plug filling a misplaced screw hole - kinda overkill but I wanted to re-use the location for a screw just a little to the left.... I thought of the right way to do it after trying one of the thousand or sow wrong ways first!
Is it any wonder I never throw stuff away? :D
  • Like 3
Posted
Never know what you’ll need on any given day.
  • Like 3
  Only 75 emoji are allowed.
