porter cable 330 sander
I bought one of these many years ago.  I was never happy with the pigtails it produced, so after I got my first ROS, it's been sitting in the (well somewhere).  After reading all the glowing reviews of it in the 1980s FWW, I decided to get it out and give it another try.  As you might expect, the foam pad was completely disintegrated.  Knowing the PC is essentially a dying breed, I just pulled out some felt pad, punched some holes in it and will give it a try.  The pad was stuck to a metal frame so I'll be using that on the felt pad.
We used those sanders in the 80’s -90’s until the ROS appeared., there still kept around in shops to get corners in between lacquer coats..
I got the pad cleaned off, put on a new felt pad, and gave it a test run with some new sandpaper.   May have gotten it's place back
