November 1, 20242 yr comment_345439 Hello, I need some advice/help. I have almost everything I need as far as hand tools go, except a couple of specialty planes. One of which is a router plane. I know if i do as I plan to with my woodworking I will need one of them eventually, but the cost of a router plane is not and probably won't be in my budget, unless I purchase one of the cheap China made knockoffs on Amazon, which I'd prefer not. I've been thinking of making one. I saw a video on YT of a guy making one using a large allen key for the blade. He heated it to red hot and let it cool, I assume annealing it, bent it out a bit and put a bevel on it. I think I could manage that, but the problem is tempering/heat treating the blade back to a level that it will hold a half decent edge. Not looking for stellar performance, just decent. Does anyone here have any idea how I could go about it, with no fancy equipment, just a map gas or propane torch? Thanks. Report
November 2, 20242 yr comment_345447 Look up Paul Sellers...as he did make one with a wood body and a chisel for a cutter... Report
November 2, 20242 yr Author comment_345448 12 minutes ago, steven newman said: Look up Paul Sellers...as he did make one with a wood body and a chisel for a cutter... Yes, I am a rabid fan. He made what he calls a poor man's hand router; basically shoved a chisel thru a 2x4. That is what i am doing now when the need arises. He also build a rather involved one with a piece of metal, possibly a chisel, it's been a long time. He upscaled that one into a kit that you can buy to build, and it is gorgeous. I'm trying to make one at almost no cost, but I will review the first video where he built it before the kit. Thanks, Steven. Edited November 2, 20242 yr by Handfoolery Report
November 3, 20242 yr comment_345507 On 11/1/2024 at 5:16 PM, Handfoolery said: but the problem is tempering/heat treating the blade back to a level that it will hold a half decent edge. Not looking for stellar performance, just decent. Does anyone here have any idea how I could go about it, with no fancy equipment, just a map gas or propane torch? Depending on the Allen wrench size, a propane torch should do it but if 1/2" or 5/8", Mapp would get there a whole lot faster. There's several YouTube videos I watched in the past about how to first heat (usually until a magnet won't stick) then once cooled (sometimes water or oil quenched) the tempering is done in an oven over a period of time. Have to do that when the Mrs. isn't home though. Sorry I can't give more particulars; it's been awhile, but a search for tempering/ heat treating steel should yield results. Just remembered, Taytools has a small one for less than $50. Reputable company. I have no affiliation. Taytools Small Router Plane Here Edited November 3, 20242 yr by Grandpadave52 Report
