March 15, 20242 yr comment_331724 Has anyone tried one of these cutters? If so what are your thoughts? I am thinking about one to use to dress up some listed boxes. Thanks Report
March 15, 20242 yr comment_331741 They should work as well as the other cutters. A straight cutter can be used with a negative rake by raising the the rear of the tool. Negative rake cutters are comfortable to use since they can be used with the tool in a more level position. Report
March 15, 20242 yr Author comment_331767 Thanks Dan, I was looking at the ones Easy Tools make. Report
March 15, 20242 yr comment_331768 I have used them (helped testing them during development) and have all 4 sizes. They work great! You will get the best results holding the tool level and turning at the highest possible speed. Hard wood, close grain species provide the best results. Elm- Report
March 15, 20242 yr comment_331784 Scrapers in general seem to be seeing more use than before. Robo Hippie is a big proponent and I've noticed Richard Raffin using them quite a bit too. Report
March 15, 20242 yr comment_331787 58 minutes ago, HandyDan said: Richard Raffin using them quite a bit too. I'm amazed at the finish he gets from his scraper work! Report
March 16, 20242 yr Author comment_331843 Thanks guys, I have been using carriers for several years and I have been getting good finishes from them. You can use them at different angles and get good results. Report
