January 31, 20242 yr comment_329003 I got a slew of 'em for my Agazzani but I'm looking for something in particular. I want the finest finish off the saw that I can get. Glueline quality. Do you know a blade, pitch, tooth, geometry, that is good like that? Mostly I run a 1" lennox carbide tipped woodmaster It's pretty good and I may use that but I want a finer cut, really smooth Edited January 31, 20242 yr by Cliff Report
January 31, 20242 yr comment_329004 Looks like that might be the best option https://www.finewoodworking.com/forum/best-bandsaw-blade-for-more-finished-cut Report
January 31, 20242 yr Author comment_329008 2 hours ago, lew said: Looks like that might be the best option https://www.finewoodworking.com/forum/best-bandsaw-blade-for-more-finished-cut if the wegotorocks guy is to be believed then the conventional way of storing a bandsaw blade is a bad idea if one wants quality cuts. Cos there's no way I can coil a blade and never drag the teeth against each other or the blade. so my 162" blade would have to be stored flat when not being used. But it does appear that the blade I use would do the best. Report
January 31, 20242 yr Popular Post comment_329039 I gave up trying to coil bandsaw blades. My health insurance is expensive enough without the extra co-pays for emergency room visits. I made a 4 point bracket system- 90° apart- attached to the shop ceiling. Store the blades there. Report
