August 11, 20233 yr Popular Post comment_319095 Been meaning to post this for a bit now. On my sister's recommendation I purchased this Hart studfinder at Walmart. I think it was about $35. I gave it a whirl this summer while working in the garage and I have to say it performs great. Without a doubt this is the best (of 3 or 4) studfinders that I have used. The three center lights come on when you are centered over the stud. And a yellow light comes on if there is an electrical run in the wall. I found it easy to use and accurate. I used it on both the wall and ceiling in the garage. The directions say it will work with lath & plaster walls. I've not tried it on that to know for sure or how well it might work on that. Based upon my limited use this summer, for the price I give this two thumbs up. Report
August 11, 20233 yr Popular Post comment_319101 That's a bit more reliably accurate than the tap tap tap method. Edited August 11, 20233 yr by Gene Howe Report
