May 13, 20233 yr Popular Post comment_314196 I just completed a solid cherry entertainment center for my neighbor. I sanded to 400 and applied 4 coats of General Finishes Armor Seal semi. An absolutely foolproof product. Report
May 13, 20233 yr comment_314215 Beautiful work Ron! Can you please explain why it's fool proof? Thanks! Report
May 13, 20233 yr Author comment_314247 5 hours ago, John Morris said: Beautiful work Ron! Can you please explain why it's fool proof? Thanks! Arm R Seal is designed to be a wipe on finish. I use bowls from Aldi’s and pour about 3 or 4 ounces in the bowl. I use a clean, new cotton rag folded into a square and apply the finish overlapping just slightly. The first coat will dry in a few hours. Lightly knick the dust nibs off with 220 sandpaper, wipe the dust and apply the next coat. Keep it up until you have the finish you want. Easy Peasy. Report
May 13, 20233 yr comment_314254 1 hour ago, Ron Dudelston said: Arm R Seal is designed to be a wipe on finish. I use bowls from Aldi’s and pour about 3 or 4 ounces in the bowl. I use a clean, new cotton rag folded into a square and apply the finish overlapping just slightly. The first coat will dry in a few hours. Lightly knick the dust nibs off with 220 sandpaper, wipe the dust and apply the next coat. Keep it up until you have the finish you want. Easy Peasy. I'll never go back to spray on finishes Ron, too much mess and fuss, I love wipe ons. Report
May 14, 20233 yr comment_314284 On 5/13/2023 at 6:28 AM, Ron Dudelston said: An absolutely foolproof product. And quite obviously, a foolproof woodworker as well. Report
