March 28, 20233 yr comment_311475 Looking for feedback on these high-temp (nylon?) adhesive knot filling systems. Both systems look like they are primarily designed for working in the flat and come with aluminum iron and "mouse plane" Has anyone tried them on a bowl/lathe specific repair? Both systems use a high wattage "hot glue" gun to apply the filler. Both systems offer multiple color options. Both are said to cut, sand, and finish like wood. Rangate Looks to be a high quality kit. Filler sticks are much more expensive at $65 / package. Knottec Similar quality kit to it's competitor and slightly less expensive. Filler sticks run about $15 / package. .40 Report
March 28, 20233 yr comment_311489 I have not used either product. Both look interesting. My first reaction was that there are limited "color" possibilities if they were to be used as a way to embellish/repair a turning. Epoxy/resin products can use a variety of ingredients to enhance the look/feel/color of a filled area. Just my 2¢ Report
March 28, 20233 yr comment_311491 It gives me the impression that it is just colored glue sticks with a heat sink to cool it off and flatten it out. Glue gun, a piece of aluminum and your wood chisels should work. https://www.amazon.com/colored-glue-sticks/s?k=colored+glue+sticks Report
March 28, 20233 yr Author comment_311493 The filler sticks are made from polyamide nylon according to Gary, sales rep that I spoke to. Hence the reason for a high temp gun. Makes me think...melted nylon rope. He sent me a link to this short video. .40 Edited March 28, 20233 yr by forty_caliber Report
March 28, 20233 yr comment_311494 No knowledge or experience of either, but thanks for the links and video Forty. Looks interesting. Hopefully I can recall this down the road when needed. Report
March 28, 20233 yr comment_311501 I searched polyamide glue sticks and there are plenty of hits. Says they are good to repair plastic and wood knots etc. Sounds like something to look into. Thanks for bringing this up. https://www.gluegun.com/blogs/news/7529066-polyamide-hot-glue-sticks Edited March 28, 20233 yr by HandyDan Report
March 28, 20233 yr Author comment_311502 Thank you very much for that link to the blog post. Big help with my research. .40 Report
March 28, 20233 yr Author comment_311504 How to do this on the cheap....<grins> Black filler sticks - $15 High Temp Glue Gun (Same as Rangate kit) - $60 Iron / Heatsink for curved surface - $10 .40 Report
October 10, 20233 yr comment_322478 Greetings fellow Woodworkers- I have used the color hot glue sticks and what a disappointing waste of time. I received recommendation from a fellow woodworker to buy the Rangate Knot Filler. I purchased the Rangate knot filler kit with temp control without any research. I must admit I was amazed of the quality of packaging, appearance of the kit, clear concise instructions, ease of use with no mess, durability to sand and accept a finish. Using the Rangate poly ( plastic) sticks exceeds all of my expectations. Do not use the glue-- it will fail and the craftsman (you) will take the hit. The poly sticks work wonderful, the trick is cleaning the void and setting the correct temp. Do a practice run. Please be advised this is not food safe. If you want food safe, pick your epoxy wisely as they are not all the same, ( I'm happy to recommend one that is food safe) I pride my shop on using the best materials and equipment I can find. Finding the best isn't always about spending more money, only 80% of the time does money drives the best. I've always said when price factors, "It just stings once". Bottom line, this is without question the Festool of heat guns. You will not be disappointed! Happy Woodworking! Report
October 11, 20233 yr comment_322492 5 hours ago, Bear Knuckle Hardwoods said: Greetings fellow Woodworkers- I have used the color hot glue sticks and what a disappointing waste of time. I received recommendation from a fellow woodworker to buy the Rangate Knot Filler. I purchased the Rangate knot filler kit with temp control without any research. I must admit I was amazed of the quality of packaging, appearance of the kit, clear concise instructions, ease of use with no mess, durability to sand and accept a finish. Using the Rangate poly ( plastic) sticks exceeds all of my expectations. Do not use the glue-- it will fail and the craftsman (you) will take the hit. The poly sticks work wonderful, the trick is cleaning the void and setting the correct temp. Do a practice run. Please be advised this is not food safe. If you want food safe, pick your epoxy wisely as they are not all the same, ( I'm happy to recommend one that is food safe) I pride my shop on using the best materials and equipment I can find. Finding the best isn't always about spending more money, only 80% of the time does money drives the best. I've always said when price factors, "It just stings once". Bottom line, this is without question the Festool of heat guns. You will not be disappointed! Happy Woodworking! Welcome Brad to The Patriot Woodworker. Thanks for sharing your expertise, experiences, and recommendations. Looking forward to hearing and seeing more from you. We have several "Lonestar State" residents here so hopefully you'll feel right at home. Glad you found us and happy you joined up. Report
