Posted
I was making some small bowls for fun and played around with beading as a decoration on them.  I had an idea that a roll pin is hardened and round and wondered whether it could be ground for this purpose.  Gave it a try and it did work after fussing with it at the grinder.  Trial and error stuff.  Here is what it looks like and it does work.  It is a 5/16" roll pin and I get a 3/16" bead.  The roll pin is mounter in a 5/16" hole drilled into a 3/8" rod.
20230121_173038.jpg.0c292bc0cdd30e00da4aa6c1dc8f0161.jpg20230121_173038.jpg.0c292bc0cdd30e00da4aa6c1dc8f0161.jpg
This is a sample of the bead I got with it.
Then I was on YouTube and saw a small spindle gouge reground for beading.  Went looking and found a Chinese made spindle gouge in my stash of auction purchases,  Took it to the grinder and success was at hand.  It makes a 1/4" bead.  The edges of  the flute are laid on the tool rest while in use and dinging them up would be bad so I found a piece of brass tubing that made the perfect guard for them.
20230121_173326.jpg.eed1a54946a16082c89261533ab895fc.jpg20230121_173342.jpg.1ac45a24a798f9820589afdefa9b8880.jpg
Here is the first bowl I used it on.  I'm in the process of putting finish on it.  It's wormy Chestnut 5" diameter.
Here's the video.
Posted
Thanks Dan. I will have to look into that being as I suck at making them with a normal gouge.
Posted
Certainly nothing wrong with those beads. I call it a success!
  Only 75 emoji are allowed.
