Popular Post DAB Posted August 15, 2022 Popular Post Report Posted August 15, 2022 Made this today, based on pictures of others i found on the web. there is a commercial one that sells for $509. this was considerably less than that. upper bin is for a pistol, bigger bin is for rifle/shotgun. KevTN, Grandpadave52, Cal and 4 others 7 Quote
lew Posted August 15, 2022 Report Posted August 15, 2022 I have to confess, I had to look this one up. Nice build. Is that a carpet or rubber liner? Grandpadave52 and Cal 2 Quote
DAB Posted August 15, 2022 Author Report Posted August 15, 2022 2x2 carpet tiles. they come in a mixed box from HD, so no two tiles are the same. made it look decent at least. lew, Cal and Grandpadave52 1 2 Quote
Grandpadave52 Posted August 16, 2022 Report Posted August 16, 2022 1 hour ago, DAB said: 2x2 carpet tiles. they come in a mixed box from HD, so no two tiles are the same. made it look decent at least. Looks good DAB. Carpet should afford reasonable protection for the guns. I assume these are primarily used during a timed event? Will they be stored inside when not in use? Cal and lew 2 Quote
DAB Posted August 16, 2022 Author Report Posted August 16, 2022 35 minutes ago, Grandpadave52 said: Looks good DAB. Carpet should afford reasonable protection for the guns. I assume these are primarily used during a timed event? Will they be stored inside when not in use? correct. they only come out during organized matches. no tools required for set up or breakdown (because no one ever brings the correct tools!), everything folds flat for storage, can lean against the wall and only take up about 4-1/2" of floor space. had to fuss with the proportions of the pistol box area, the drawing i had made from another youtube video had that area way too big. so kept cutting it down until it seemed about right for most common pistols. mine fit easily, so other match type guns should also fit well. about $60 in materials, i'll get exact numbers tomorrow when i scan receipts. way better than $508.....yikes. the club has money....but let's spend it wisely. lew, Grandpadave52, Cal and 1 other 4 Quote
Grandpadave52 Posted August 16, 2022 Report Posted August 16, 2022 Good looking design. It's probably not much heavier than a corn-hole game board?? That said only thing extra I might consider would be adding a pair of small wheels (think plastic wheels like on a push mower) to roll them to/from location. I still need to do that to our corn-hole set. Just thinking of my shoulders and now my back after surgery. Of course the other option is just let all the "young bucks" move 'em. lew and Cal 2 Quote
DAB Posted August 16, 2022 Author Report Posted August 16, 2022 Ground at the range is uneven gravel. You’d need 6-8” wheels at least. One person can carry it. Cal, Grandpadave52 and lew 3 Quote
DAB Posted August 16, 2022 Author Report Posted August 16, 2022 In case anyone is interested, just checked my receipts, and the total for 2 complete boxes comes to $144.93, or $72.47 each. Just a bit less than the $509 quoted elsewhere. But I didn't paint these pretty white..... Grandpadave52 and lew 2 Quote
DAB Posted August 16, 2022 Author Report Posted August 16, 2022 some sample guns in the dump box: full sized Beretta 92 pistol, AR-15 type rifle (stock fully extended), 12 ga semi-auto shotgun (18" barrel). All guns that would be commonly seen and used at a 2 or 3 gun match. KevTN, Grandpadave52, Cal and 1 other 2 2 Quote
John Morris Posted August 16, 2022 Report Posted August 16, 2022 That is so cool, I could see using this for my BP rifles and revolvers too, thanks for the idea Dab! Grandpadave52, DAB, lew and 1 other 4 Quote
Grandpadave52 Posted August 17, 2022 Report Posted August 17, 2022 Awesome DAB. Hmmm...I can see usefulness for one of these on a private range where one is just target shooting various guns. Should beats the truck tailgate. Cal and lew 2 Quote
DAB Posted August 17, 2022 Author Report Posted August 17, 2022 If you need details, I could sketch it out with dimensions. Post the pdf. some of this was trial and error. Grandpadave52, Cal and lew 2 1 Quote
Grandpadave52 Posted August 17, 2022 Report Posted August 17, 2022 That would be greatly appreciated DAB. Unlikely I'd get one made this year now but would be interested in having plans back. Couple of these would make a good donation to our local sheriff's department in exchange for me getting access to their range. SIL is a jail officer. No rush on your part...when it's convenient for you and you're out of things to do. THANKS AGAIN!! DAB, Cal and lew 3 Quote
KevTN Posted August 18, 2022 Report Posted August 18, 2022 Nice job DAB! Cal and Grandpadave52 2 Quote
Popular Post DAB Posted August 19, 2022 Author Popular Post Report Posted August 19, 2022 and then there were two: Gene Howe, Gerald, KevTN and 2 others 5 Quote
DAB Posted October 20 Author Report Posted October 20 well, it's been a little longer than planned but i finally got around to posting the "how to" in this new thread> lew and Grandpadave52 2 Quote
